20" wheels. Do it again? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
Sponsored by Discount Tire Direct
Old 05-08-2009, 04:49 AM   #1 (permalink)
Those of you with the factory 20" wheels, is there any reason that you wish you hadn't gone that route?
I think they look awesome, but if there are any balancing or wearing issues, or if you've found that tire replacement is way out of line, I'd like to know. Thanks!
ForeignCarsStink is offline
Old 05-09-2009, 02:57 PM   #2 (permalink)
Discount Tire's Avatar
I compare the tire prices between the 275/70-18's and 275/65-20's (two OE options for the newer F-250) and found that the tire prices are roughly the same. In fact, there are tires that cost less in the 20" size. Even the optional 275/65-18 models are in line with the other sizes listed. Lower profile tires like the 275/65-20 size are typically easier to balance as well.
Low Prices! More Choices! FREE Shipping!
At The Store: www.discounttire.com
To Your Door:www.discounttiredirect.com
Sales and Technical: 1.888.459.4080
Found a Lower Delivered Price?
Useful Links:
Tire Size Calculator
Current Promotions
Wheels & Tires 101
Discount Tire is offline
Old 06-20-2009, 10:42 PM   #3 (permalink)
My Photos: (6)
Send a message via AIM to blizzardwarrior7
Yea in terms of drivability I would say they are the same....When you start moving into larger tire sizes typically the 20" will be more expensive than an 18".
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
blizzardwarrior7 is offline
Old 06-24-2009, 02:22 PM   #4 (permalink)
I don't think if there is any wearing and balancing issue will come up. They give good performance.
Kia Optima 2009 Kia Headlights
samabhi126 is offline
Old 10-16-2009, 03:22 PM   #5 (permalink)
I had an 05 350 dsl crew 4x4 with 18's. Put on the factory 20's w/ the goodyears. The ride was significantly worse and put the 18's back. The 20's definitely look better but its not worth it. I think its a combination of the increased weight of the 20's (there's a lot more metal) combined with the shorter (stiffer) sidewalls.
1999.5 F350 DRW Crew 4x4 7.3L 6-Spd XLT Flatbed 4.10L 347k. ??12 gears - can't one be for highways / expressways??
Sold -1999.5 F350 SRW Crew LB XLT 4x4 7.3L 6-spd 3.73L 355k -
Sold - 2005 F350 SRW Crew LB Lariat Fx4 3.73L 6L Auto almost all options
tequila0 is offline
