4 part tire/rim question for 02' F350 dually
1. What is the largest tire that will fit an 02' F350 dually without having to use a spacer?
2. Can anyone recommend a good tire/rim dealer in the Norfolk Va. where I can get prices on new tires and rims for a dually?
3. Who makes good dually rims in the 19' to 19.5" range?
4. Will rims off an F450 (the 19.5" ones) fit an F350 or are the 450's more lugs?
Just bought an 02' dually and I'm needing new tires. Thinking about maybe going up a few sizes in the rim deparment. Also does anyone know of a place that re-finishes rims in case I opt to keep the originals?
Thanks in advance!
NEW TRUCK: 2002 F350 CC,Short Bed, Dually w/ 7.3L, Air Raid intake, 3 gauge pod w/ISSPRO V2 gauges, Overhead gauge mount with DP Tuner gauge switch, DP F6 tuner w/stock, 1300 hi idle, 80 econo, 120 race, 40 & 80 tow and decel tunes. 4" turbo back Magnaflow exhaust.
http://community.webshots.com/album/576806969VrqaZx
OLD TRUCK:97' F250 4x4 crew cab. 4:10 gears,High Idle mod, Dana 60 conversion using 3"SKY RSK w/03' SD springs and 3 3/4" rear blocks to level. Tymar, Issopro gauges on 3 gauge pod, 3" down pipe, shimmed FPR and DP tuner 6 pos. chip (12-13-07).
http://community.webshots.com/user/amberjax
