Bilstein Shock Mounting Question - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
Sponsored by Discount Tire
Old 11-19-2012, 01:58 AM   #1 (permalink)
Supporting Member
My Photos: (9)
I installed four Bilstien Shocks a couple weeks ago and have a question about the Blue Rubber Boots. I mounted the shocks with the writing on them rightside up, this put the rubber boots on the bottom. Now the blue rubber boots stick out like a sore thumb when you are behind the truck. Maybe it's just me but I don't like the appearance. I don't think it will hurt to flip the shocks so the boots are on top. So, does anyone think it will hurt to mount Bilstiens upside down?
Thanks for Listening,
Bill
2002 F350 CC, LB, SRW, 4X4, 6 Speed. Hutch Pre-Pump and In Tank Mod, Housted T, Harpooned Tank. LL#8 Gone. EPI Flex Pipe. Scangage2. Towing 2013 Arctic Fox 27-5L 5th. Wheel
Traildust is offline   Reply With Quote
Old 11-19-2012, 09:07 AM   #2 (permalink)
fordsforever73's Avatar
My Photos: (21)
Feedback Score: 2 reviews
The boots are supposed to be on top.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. Many other custom features.
fordsforever73 is offline   Reply With Quote
Old 11-19-2012, 09:18 AM   #3 (permalink)
bugman's Avatar
My Photos: (12)
It doesn't matter top or bottom it is your choice.
bugman is offline   Reply With Quote
Old 11-19-2012, 09:23 AM   #4 (permalink)
My Photos: (21)
I figure, if the boots are on the bottom, they will eventually fill up with dirt and water...can't be good for seals.
Old 11-19-2012, 09:41 AM   #5 (permalink)
bugman's Avatar
My Photos: (12)
The same can be said if the boots are on the top unless you are parking the truck in water that only comes up to the bottom of the shock. If water can get into it when the boot is on the bottom it is going to get into it when the boot it on the top.
Old 11-19-2012, 10:46 AM   #6 (permalink)
Term3's Avatar
Isn't the whole idea of boots is to keep dirt out? To make sure water doesn't accumulate in the boot just do what I did and make a small hole in the boot near the bottom. A small hand held paper punch makes a nice size hole.
Term3 is offline   Reply With Quote
Old 11-19-2012, 12:45 PM   #7 (permalink)
Supporting Member
My Photos: (9)
After I mounted them I really thought they were upside down. I did search here and other sites and common thought seemed to be, mount them so the writing on the shock was rightside up.
I am going to flip them and this brings up a new important queston. Is there any trick any of you know on how to compress the shocks to get them into their mounts. The darned things will expand as soon as I pull them out.
Bill
Old 11-19-2012, 05:03 PM   #8 (permalink)
Tony M 6.7's Avatar
The last thing I would be worried about is the color of the boot considering the improved ride and handling of the Bilsteins.
2012 F-350 Crew Cab, Lariat XLT Ultimate, 4X4, Vermillion Red/Black Leather, FX/4, 3.55 axles, E locker, Awesome truck!!
Tony M 6.7 is offline   Reply With Quote
Old 11-19-2012, 06:47 PM   #9 (permalink)
Iam4MSU's Avatar
When you mount the shock just compress it with your arms with steady pressure. I would try to install the top first then push the bottom to its mount. You can also take large nylon ties and loop one around each end while they are still mounted and then take a third tie and strap the 2 loops together to limit the amount the shock opens.
They are really not hard to compress. The shocks are for dampening.
2004 F250 Crew Cab King Ranch Lariat FX4 Saddle Leather 6.0 L FUMOTO Valve
AIRAID 4" straight No CAT No MUFF
Nitto Terra Grapplers All Terrain LT285/75R16 10 PR Everything else pretty much stock
NEW Ranchos installed 8/15/2010
WORK IN PROGRESS - R&R EGR COOLER, OIL COOLER, THERMOSTAT, TURBO BOLTS, GASKETS, ORINGS, and adding a COOLANT FILTER WITH NEW COOLANT AND FLUSH
Anyone Got Birds? Will Travel to Hunt!
We are all just Village Idiots,
Enamoured with our own shadow,
Oblivious to the setting sun!
Iam4MSU is offline   Reply With Quote
Old 11-25-2012, 11:49 PM   #10 (permalink)
Supporting Member
My Photos: (9)
This entire thread is mute. I tried to flip the shocks only to find they only go on one way. Top mount bolt is bigger than the bottom one, this puts the boot on the bottom and like it or not I am stuck with it. If I had looked at the shocks before I mounted them I would have saw that.
Old 12-02-2012, 08:33 AM   #11 (permalink)
Tony M 6.7's Avatar
Mine on my 2012 mount with the blue dust cover up. Rear took a whole 20 minutes to install. What a difference in ride quality.
