Dually Tires - Diesel Forum - TheDieselStop.com
Sponsored by Discount Tire
post #1 of 11 (permalink) Old 03-18-2009, 08:47 PM Thread Starter
Dually Tires
Does anyone know of a taller Load Range E tire that I can put on a Dually. My tires are 17 inch. I would like to go a little taller, but I need to stay fairly narrow because of the duals. I can't seem to find anything.
2008 F-350 Dually XLT 6.4, 6spd, 4.10, Crew cab, Manual 4x4, Forest Green, 5" Diamond Eye Exhaust, AFE Stage 2 Intake, SCT Programmer
GreenDually is offline
post #2 of 11 (permalink) Old 03-18-2009, 09:51 PM
Send a message via AIM to blizzardwarrior7
Nitto TERRA GRAPPLER Tires from National Tire & Wheel @ NTW
Should be a 33.5x11.5, a 34x12 and a 35x13 all in 17s and load range E.
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
blizzardwarrior7 is offline
post #3 of 11 (permalink) Old 03-18-2009, 10:22 PM
burnetma's Avatar
This is a timely discussion.
I bought my truck used and it has the Nitto tires on it (295-75/R17D). You can not put a half dollar edge wise between the tires at the bottom when unloaded. The previous owner ran the truck this way for some time, but I am concerned about the tires heating and having a sidewall blow out.
The spacers that are sold at that website start at $175/pair! Personally, I do not like the bigger tires, so I have to decide whether or not to buy spacers or new tires.
2008 F350 FX4 Crew, 4x4, 6.4L, Torqueshift, 4.30, tow command, leather, power everything. 75k+ miles. Built 4/17/2007 (Job 1), Purchased used 3/16/2009
2010 Mustang GT Premium - 4.6L-3V, 5 Speed, Grabber Blue - Now this is FUN!
1997 F250 EXT Cab, 4x4, E4OD, 4.10, 273k+ miles.
Modifications: Pyro & boost guage, 202 T-stat, transmission cooler & Tymar - SOLD!!!!!!!
2004 John Deere 5420 MFWD Utility Tractor with 541 MSL Loader.
burnetma is offline
post #4 of 11 (permalink) Old 03-19-2009, 12:36 AM
Heres some for 70 bucks eBay Motors: ALUMINUM WHEEL SPACERS 8 Lug Dually Chevy Duramax 1/2" (item 120394024636 end time Mar-28-09 13:14:17 PDT)
post #5 of 11 (permalink) Old 03-19-2009, 10:13 AM
SmokeyWren's Avatar
My Photos: (45)
Your stock rims are your limiter. They are 6.5" wide. The widest tire that will safely fit on those rims - per the Tire and Rim Assn. and all tire manufacturers - is LT245/75R17. You already have LT245/75R17 tires, so you shouldn't go any bigger unless you also replace the rims with wider rims.
Spacers between dual rims are killers - and especially cheap spacers. Do't do it. If you can't live without bigger tires, then order custom, wider, rims with the right offset to match your tire choice.
The next size up is LT265/75R17. That size requires rims a minimum of 7" wide. Your rims are only 6.5" wide.
With custom rims, you can go to a lot bigger tire. One of our members from Wyoming showed up at the North Texas rally in October with much bigger tires. The truck looked great, with adequate space between the duals. But not cheap. Those tires, rims, and lift needed to clear the tires cost him a small fortune. But he took home the trophy for the crowd favorite at the rally.
SmokeyWren is offline
post #6 of 11 (permalink) Old 03-19-2009, 02:49 PM
burnetma's Avatar
So why did any tire dealer put those tires on what I believe are my factory rims and why did it ever pass inspection that way?
I am going back to LT245/75R17E tires as I believe it is the right thing to do for me. Although it is certainly going to be painful at $1170!
I am going to talk to the dealer and inspector and ask them what they can do here. Afterall, there is enough blame to go around here. The inspection station should not have passed this unit with unsafe rim/tire combination (I am checking NY law to get the specifics) and the dealer should not have sold a vehicle (with inspection sticker) that should not have passed.
burnetma is offline
post #7 of 11 (permalink) Old 03-23-2009, 10:57 PM
burnetma's Avatar
FYI, I made the change back to stock and I could not be happier.
burnetma is offline
post #8 of 11 (permalink) Old 05-04-2009, 05:10 PM
Did you happen to have any pictures of those tires mounted on the wheels? I don't foresee the tire sealing on the bead being that wide, the minimum width of wheel for those tires are at 8" wide.
I know this goes against what SmokeyWren stated and I don't intend to offend him either but I'm looking at going to a 265/70/17 on my dually, & yes I do realize that my wheels are .5" too narrow.
06 F-350 CrewCab 6.0L, 4.10LS, DRW, FX4, short bed, moonroof, power slider, back-up sensors, black on tan heated leather
Quickerthanu is offline
post #9 of 11 (permalink) Old 04-21-2011, 12:47 PM
I am using 215 85r 16 inch tires on my 95 dually, can I use 235 85r 16 also?
Manfrog is offline
post #10 of 11 (permalink) Old 04-21-2011, 07:45 PM
SmokeyWren's Avatar
My Photos: (45)
Yes.
LT215/85R16E were standard, but LT235/85R16E were optional on your truck.
However, if you go to LT235/85R16E tires, your speedo will be slower by 5% (3.5 MPH at 70 MPH). IOW, if your speedo is accurate with the 215s, then with the 235s when you speedo shows 70, your speed on radar (or GPS) will be 73.5 MPH.
It's an easy fix for your Ford dealer (or anyone with the right scan tool that can access the ABS module) to calibrate the computer for 654 tire revs/mile compared to the 687 revs/mile for the 215s.
post #11 of 11 (permalink) Old 04-27-2011, 12:41 AM
burnetma's Avatar
Here are the two best photos I have.
What NOT to do on a dually.
Name:	Rear Tires.JPG
ID:	10897   Click image for larger version
burnetma is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
