Installed skyjacker 6" lift and having issues - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
Sponsored by Discount Tire Direct
Old 06-21-2009, 04:43 AM   #1 (permalink)
Hey everybody,
I'm new here, but have been browsing around. New to the whole diesel and truck thing all together. I installed a skyjacker 6" soft ride lift, with new front and rear springs about 5K miles ago. When I put the lift on the rear of my truck was sitting higher, I assumed and was told that the rear springs would settle and I'd be level. Well I'm still not level, and I've hauled a couple heavy loads for a few hundred miles. I left the stock rear block in since I got replacement springs. The rear block is like 3". So my question is do I need to a leveling kit or just do an add a leaf in the front to get it to sit level? It's an early '03 w/7.3L, crew cab, long bed.
Any help would be greatly appreciated,
FORDCRAZY is offline
Old 06-22-2009, 02:34 PM   #2 (permalink)
Feedback Score: 3 reviews
Measure what the amount of either front lift or rear reduction you need the either get a hanger kit..2" min or a lower rear block. If you raise the front you should use a adj track bar.
I wouldn't think of adding a add-a-leaf to lift springs
Cary
Cary
caryt is offline
Old 06-28-2009, 07:42 PM   #3 (permalink)
get the smaller factory block for the rear. i ran into the same thing
2002 f-250 WITH SOME STUFF
recon250 is offline
Old 07-14-2009, 08:24 AM   #4 (permalink)
Thanks guys!
So what size is the smaller rear block then? I know mine is like 3 1/2"s or something right around there. Is the smaller block for a 3/4 ton? I would assume all 1 ton's came with the same size block, right?
Old 07-14-2009, 08:53 AM   #5 (permalink)
Get F250 4x4 rear blocks or eliminate them entirely depending on how far down you need to go to get the truck with the rake you want or level.
02 SWB CC 4x4 auto, AIS, DPTunerF5, FTVB, 4" Banks Monster SS Exhaust, HPOXover, AirDog, Amsoil ByPass, Centramatics
blackout is offline
Old 07-17-2009, 08:19 AM   #6 (permalink)
My Photos: (5)
I just did a 6" springs front and rear lift on my f250. Mine sits 1 inch taller in the rear with no blocks. btw my truck had 2" factory blocks.
2002 7.3 F-250 4x4 Lariat crewcab SWB
DP Tuner 80HP Economy flashed PCM
zoodad mod, harpooned tank
turbobobby is offline
