lift law in MA? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
Sponsored by Discount Tire Direct
Old 07-26-2009, 06:41 AM   #1 (permalink)
lift law in MA?
Well I tried to post in a cop forum but they scrub the posts to weed out the spam. Takes a while to have it posted. Anyway I was wondering if anyone knew the law for max allowable lift. Or know someone to talk to before I get mine. oh yeah this is Massachusetts so the laws suck.
My question is…
I want a 6” lift. Per calculation my max mechanical lift is 4.4”. therefore my max tire size increase is also 4.4”. so that makes a total lift of 8.8” right? If you look at (2) does this mean I could have a 6”mechanical lift with a 2” tire to be at 8”? or is it strictly 4.4"
Well here is the law….
(1) The maximum mechanical lift for four wheel drive motor vehicles
shall be calculated by multiplying the wheel base times the wheel track,
and dividing the product by a safety factor of 2200
The outside diameter of the largest tire size available from the original manufacturer as standard or optional equipment for the particular motor vehicle may also be increased up to an amount equal to the maximum mechanical lift calculated.
(2) The maximum combined mechanical and tire lift shall be no greater
than the sum of the maximum mechanical lift and increased tire size
calculated for the particular vehicle.
the reason i ask is not because of cops bugging me but more to make sure i can get an inspection sticker after spending 3g's on a lift.
Thanks in advance.
f.polcari is offline
Old 07-29-2009, 05:57 PM   #2 (permalink)
Discount Tire's Avatar
I wish I could point you in a specific direction for this but I can't. I would try calling a lift shop in your area or even a dealership that has a good aftermarket parts department. Hopefully others here will chime in and help you more than I can. I would imagine there are other guys here are are in the same situation.
Good luck. When you do figure out what size you are going to do with let us know. We would be happy to get you set up with a deal.
-Travis
Low Prices! More Choices! FREE Shipping!
At The Store: www.discounttire.com
To Your Door:www.discounttiredirect.com
Sales and Technical: 1.888.459.4080
Found a Lower Delivered Price?
Useful Links:
Tire Size Calculator
Current Promotions
Wheels & Tires 101
Discount Tire is offline
Old 08-05-2009, 08:53 PM   #3 (permalink)
ma lift law
You got the formula right but I believe that the 4.4 includes lift plus tires, making it a total of 4.4. I had a 4" kit on a regular cab with 285 75 16 (32 11.50 16) tires and had a hard time getting a sticker this year with the new inspection program. I just put a 5" kit and 35" tires on my new ext cab 6' bed. Hopefully I wont have any problems next year but F it Ma lift laws suck. It depends where you go, my friend has a reg cab with 8" lift and 37" tires never has a problem getting a sticker. I think stations in metro west are hard compared to western mass or even worcester county.
bigdg12 is offline
Old 08-15-2009, 08:56 PM   #4 (permalink)
Gotrox's Avatar
My Photos: (6)
In PA you can't lift it more then 2 inches and can't have tires more than 2 sizes over stock. I'm liking Cali more and more, no lift laws, just pass your smog, nothing else matters.
2003 F-350 - 4x4, 6.0L, Auto, 52250 miles, Straight-piped, AFE filter, ProSport gauges, leveled, pro-comp 16x10s, 35" Nittos
Gotrox is offline
Old 08-16-2009, 04:56 PM   #5 (permalink)
man that sux! only 2"! thanks for the replies.... i think im just going to get the 6" and hope for the best. ouo traction block and rize front lift
Old 08-20-2009, 12:19 PM   #6 (permalink)
My Photos: (6)
Send a message via AIM to blizzardwarrior7
Where in MA are you?
The law is this: wheelbase x wheeltrack divided by 2200.
This give you the maximum amount of mechanical lift, and the maximum amount of inches over the O.E.M. Tire size. If the OEM tire was available in different sizes, select the largest diameter one.
If you do the formula and get 4.4, round down to 4. You can lift the vehicle 4"s and go 4"s over the current tire size. Giving you a total lift of 6"s, because a 4" increase in tire size is only a 2" increase in tire radius.
I drive around with an 8" an 38"s and have never been pulled over for it. I also had one lifted 7"s on 37"s with no problems.....6" lift on 37"s would be no problem.
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
blizzardwarrior7 is offline
