New Nitto Trail Grappler M/T...due Sept '09 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
Sponsored by Discount Tire Direct
Old 07-06-2009, 07:02 PM   #1 (permalink)
Discount Tire's Avatar
Click here for: Sizes, Specs, and Pricing on The Nitto Trail Grappler M/T
The following sizes will be available by years end:
LT285/70R16 E 125/122P - Released
LT295/70R17 E 121/118P - Released
35x12.50R17LT E 121Q - Released
LT285/65R18 E 125/122Q - Released
LT295/70R18 E 129/126Q - Released
35x12.50R18LT E 123Q - Released
LT295/55R20 E 123/120Q - Release
LT295/65R20 E 129/126Q - TBA
LT305/55R20 E 121/118Q - Released
35x12.50R20LT E 126Q - Released
37x12.50R20LT E 126Q - Released
37x13.50R22LT E 123Q -TBA
38x13.50R24LT E 123Q - TBA
The all-new Trail Grappler™ M/T blends some of the off-road performance of the Mud Grappler™ with the on-road comfort of the Terra Grappler™ to create a tire that is both aggressive and quiet. For off-road performance, the sidewall combines a 3-ply high turn-up construction with a thick rubber compound that cushions the tire and helps prevent punctures. On the tread surface, the blocks are configured to provide additional biting edges that command lateral stability and enhance forward traction. For on-road comfort, Nitto's engineers used advanced sound analysis equipment to reduce the noise levels commonly associated with off-road tires. The internal construction and tread design also help optimize treadlife. Two wide steel belts provide a stable base for the tire and increase tread strength. This advanced construction provides optimal uniformity and reduces irregular wear.
Nitto promises the Trail Grappler MT will be the next best thing to hit the Grappler line up. For those of you who love the Terra Grappler but want a little more bite and off-road performance without stepping up to the Mud Grappler, this tire is for you. Nitto manufactures their Grapplers with the most up to date manufacturing technologies. Nitto uses segmented molds that fit together like puzzle pieces, and continuous wound steel belting. These two manufacturing processes alone make a huge difference when it comes to balancing. They also help to dramatically reduce the tires chance for tread separation. Add to these, Nitto's highly sophisticated rubber compounds and the fact that Nitto builds 90% of their Grapplers in the USA and you have a winning combination.
Click the image below to be redirected to Nitto's interactive site for more detailed information on the Trail Grappler M/T.
Reviews & Wright Ups
Peterson 4 Wheel and Off-Road Trail Grappler Article
Four Wheeler Nitto Trail Grappler MT Tire Test
Low Prices! More Choices! FREE Shipping!
At The Store: www.discounttire.com
To Your Door:www.discounttiredirect.com
Sales and Technical: 1.888.459.4080
Found a Lower Delivered Price?
Useful Links:
Tire Size Calculator
Current Promotions
Wheels & Tires 101
Discount Tire is offline
Old 09-09-2009, 07:24 PM   #2 (permalink)
Update in post 3
Useful Links:
Current Promotions
Wheels & Tires 101
Old 09-14-2009, 06:38 PM   #3 (permalink)
Three sizes were released today.
Nitto Trail Grappler Sizes, Specs and Pricing
Also Peterson 4 wheel and Off-Road just posted an article on this tire: Peterson 4 Wheel and Off-Road Trail Grappler Article
Useful Links:
Current Promotions
Wheels & Tires 101
Old 09-15-2009, 08:20 PM   #4 (permalink)
*Bump*
New content added to the OP
Useful Links:
Current Promotions
Wheels & Tires 101
Old 11-12-2009, 11:25 PM   #5 (permalink)
Sabre6's Avatar
06 F250 4x4
I notice they are not made in the OEM size 275/70-18. What are my alternatives? I want to keep them on my OEM wheels (I have the polished Aluminum with the larger holes).
Sabre 6
2006 F250 6.0L PSD 4x4 Crew Cab SB SRW
Amarillo Pkg "Scream'n "CAV" Yellow" Black Interior
SCT X3 Innovative, Accufab Intake Elbow, Zoodad Mod, Fog Light Overide Mod, FS2500 BOF
Harpoon Mod, RECON Cab Lights, Fumoto'd
Army~Air Cav/Attack Pilot OH-58/AH-1/AH-64
"You Can Run But You Can't Hide..."
Gary Owen!!! Fast Guns!!!
Sabre6 is offline
Old 11-13-2009, 03:34 PM   #6 (permalink)
The Trail Grappler in sizes 285/65-18 and 295/70-18 are approved for your factory wheels. The 285's will be a tad shorter than the stock size and the 295's will be about 1.25" taller than your stock size. The 295's might rub at full turn and a stress may but this can be easily fixed with some trimming
Useful Links:
Current Promotions
Wheels & Tires 101
Old 11-13-2009, 05:10 PM   #7 (permalink)
boomboom's Avatar
Remember that 1.25 " only = 5/8" when your checking for interferance issues.
boomboom is offline
Old 11-13-2009, 07:29 PM   #8 (permalink)
Sabre6's Avatar
Thanks guys! I appreciate your help with the sizing. I really like the new NITTOs, going to get me a set after Christmas, they will look sharp and more importantly, give me the traction I am looking for on and off road.
Sabre 6
Sabre6 is offline
Old 11-13-2009, 07:57 PM   #9 (permalink)
RIStroker2000's Avatar
Send a message via AIM to RIStroker2000
ugggg its too bad i just put the AT's on the truck.. booooooooo
2000 7.3 Extended Cab Long Bed Lariat.... Van turbo (1.15ex.), Casserly stage 1's, DP tuned [()], IH uppies, 07 grille & lights, dieselsite boots, autometer gauges, 6637, walker BTM, CCV Mod, Oil X over, ITP boost anialator, Foil Delete, Add a leaf HD rear springs, leveled, 285 Nitto's, 200 gal. spray tank, 8' Fisher plow winged, 2.5 yard sander.
(waiting for reasonable answers on reasonable questions)
1999 Maxima- 3.5 swap turbo. runs low 12's 1/4 mile
2008 Subaru Legacy (STI swapped)
RIStroker2000 is offline
Old 11-27-2009, 08:42 PM   #10 (permalink)
Does anyone have any idea on how long these tires will last in comparison to the Toyo Open Country MT's? I ran a set of the Toyo Tires for about 60K miles without any problems... but these are about $100/ tires.
- 05' F350 4x4 6.0PSD
- 89' Twin Turbo Mustang
killacal is offline
Old 11-28-2009, 07:38 AM   #11 (permalink)
I ordered a set of 285/65R18 yesterday and took advantage of the $50 blackfriday savings. I also bought new wheels for another $50 savings.
2006 F-350 6.0 PSD,XLT,CC,FX4,LB, Tow Command, Camper Package, Wet Okole Camo Covers, Upfitter Switches, High Idle Mod, Line-X, ARE Z Series Cap, Power Elbow, Dieselsite Coolant Filtration,Oil Guard Filtration, 4" Magnaflow straight pipe, 08 Mirrors, B5+DK, Magnefine PS filter,BD CCV,Spartan Phalanx, 08 tranny pan+filter, 285/65R18Nitto Grappler M/T on Ballistic Hostel wheels,Blue Fuel Spring
Rob.D is offline
Old 12-15-2009, 01:54 AM   #12 (permalink)
So anyone have any feedback on these? The pictures look sick! I have 20" KMC's on my 2003. Currently running Nitto Terra Grapplers that I'm thrilled with, but would like the look of something a little more aggressive. I do a lot of highway driving, so if they are loud or vibrate a lot, I'm not buying.
Hello... 2008 XLT, C.C. 6.4, 4x4
Stock for now...
Bye bye...2003 C.C. 6.0 4x4, AFE 4" Turbo back from DPPI; 2" Leveling kit; 20x10 KMC Rockstars w/ 33" Nitto Terra Grapplers
LXXXTSY is offline
Old 12-16-2009, 05:28 AM   #13 (permalink)
I just installed a set on monday, 285/65R18. I replace the stock Continetal tires. The tires look great! I do notice a little more vibration and noise over stock, but I think that's to be expected. On the highway @ 70mph just a slight howl, no vibration. We will be traveling for Chistmas this weekend, curious to see if the wife notices any increase in noise/vibration. I'lll report back.
Rob.D is offline
Old 12-16-2009, 12:51 PM   #14 (permalink)
wheelbase's Avatar
How are these tires for towing? Anyone???
Thanks!
2005 F350 Superduty 6.0L CrewCab LB 4x4 Black Lariat Loaded w/ S&B Cold Air Intake / 2008 Telescoping Mirrors / Recon Smoked Cab Lights & Side Markers / Toyo Open Country A/Ts / Bilstein Shocks / MBRP Cat Back Exhaust (Downpipe & delete pipe is in the garage until warranty ends) / Edge Insight / Cab off repair replaced every gasket in engine after buyback process ended with a nice big check from Ford (Oil Leaks) / Run Rotella T 15W 40 / Stanadyne Performance Formula in every tank
2005 Denali (Dutchmen) Travel Trailer 29RK-DSL
2003 Black Lab (Magnum) 105 LBs and runs on Pro-Plan
wheelbase is offline
Old 12-16-2009, 04:10 PM   #15 (permalink)
One of the guys here at my office installed a set of Trail Grapplers on his Duramax and towed with them a few weeks ago. He said he was very pleased with them, that they tracked "straight as an arrow" and there was no squirm what so ever. He currently has about 1000 miles on them. I'd share some pictures of them on his truck but its a Chevy so if you want to see them PM me and I'll give you a link.
Useful Links:
Current Promotions
Wheels & Tires 101
