The fords are known for less than nice brake lines they break internally and form a check valve, easiest way to check is to smash the brakes with the engine on and turn the engine off and get a pair of channelocks and gently squeeze the brakeline working your way down until you see the calipers release their tension(you'll notice). Or you could buy the three rear lines and change them out. I changed the front as well and had to change all four calipers, front right locked up and both rears... GRRRRR
He didn't test properly or know to so we don't know his parts are inferior or if he has tried testing as directed. He is he to find answers. He does not nessasarily need somebody else to do the repairs. He has been getting sound advise here.
Ok good talk
Yes. After doing research, it appears rusting of the lines is a common theme and would make perfect sense why it is happening on just one caliper. Is the best route to buy pre-bent stainless lines?
They don't have to be stainless.
Get good at doing double flares and make your own lines.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
