replacing ball joints on 2005 F-250, have seal question
I haven't seen a write up specifically for the '05. But based on the write ups I've seen for earlier model years, the only seal that seems to be required to be replaced is the large outer one that is pressed on the outer u-joint shaft.
I haven't torn anything apart yet, so I don't know what shape things are in (other than the ball joints being bad, will replace with Moog).
I'm trying to discern what other seals should be replaced, i.e. "it's a good idea to replace this one because it's been disturbed", vs "don't waste your money replacing this seal, it's ok to re-use" kinda thing.
So, here's what I've got so far:
5C3Z*3254*A (pressed on outer seal) REPLACE
2C3Z*3254*AA (inner dust seal?) keep or replace?
5C3Z*4A322*AA (yellow steering knuckle oring) keep or replace?
5C3Z*1K106*AB (seak kit for hub lock) keep or replace?
(am I missing anything?)
Thoughts? I'm a "do it right the first time" kinda guy, but didn't want to waste money on parts that truly can be reused.
Right, don't remember if its described or not but I made an extra effort to "clean" all traces of prior seal material from the axle seat before driving the new one on... It did require some pretty intense 2lb short handle sledge strikes.
Stock 03 6.0, F250 Crew SB, 4x4 P/U, 109,400 miles, Scan Gauge II (TFT, ECT, EOT, BST), Fuel press blue spring U/G, HFCM water separator Drain plug, BD Diesel Performance Intake Hose & Clamp Kit, Shell Rotella T6 5w-40, Power Service Diesel Kleen +Cetane Boost, Autoenginuity Enhanced Ford & GM Interfaces
I'm always a fan of these style write-ups. I'm going to be replacing front U-joints on my friends F350 in the next week or so. I plan to follow most of this procedure... minus the part where he uses a TORQUE WRENCH to loosen bolts.
Let me know how that works out for you. I will be doing my 04 F-350 in a few weeks. Thanks
Just wanted to close out this thread from my original question. I ended up replacing all seals that I disturbed (some you physically have to because of destruction from removal). Figured the cost of a new seal was worth more than having to pull stuff back apart again.
