Good day all,
I have a question that I cant seem to find an answer for. My truck is a 2015 CC LWB SRW F350 4x4 Diesel. I ordered it with the camper package. It has 3.55 gears and no other front suspension upgrade choices from the factory. The VIN tag inside the drivers door has a front GAWR of 6000# with a spring code of CCLL on the bottom right of the VIN tag. When I cross reference 6000# factory coil springs with the coil spring codes from Ford I see F81A-5310-AHD is the 6000# coil spring. The actual tag attached to my front coils both read 5C34-5310-ACD and according to that code it's a 4000# coil spring.
Did the factory put it in the wrong springs?
John
John
