tire pressure? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
Sponsored by Discount Tire
Old 01-03-2013, 12:00 PM   #1 (permalink)
tire pressure?
My truck doesn't have the B-pillar sticker (or door sticker) that defines the recommended tire pressure. Based on a friend's similar truck, I've used 60 psi, but have always been curious what the real psi was from the factory. The truck is stock, here's the VIN: 1FTSW21P55ED12257. Anybody out there that can look up my sticker based on the VIN?
2005 F-250 XLT 6.0L Crew Cab 4x4
BulletProof Oil Cooler/EGR Cooler; updated STC fitting; updated turbo oil drain tube; fuel pressure regulator spring upgrade (blue spring); Line-X bedliner; Jimmy Jammers; ScanGaugeII; Moog ball joints; ~103,000 miles
sgivens is offline   Reply With Quote
Old 01-03-2013, 02:53 PM   #2 (permalink)
01f25073's Avatar
My truck is 55 psi front and 70 psi rear according to the sticker.
2001 F-250 4X4 CC SB 7.3 4R100 3.73, BFGoodrich All-Terrain TA/KO, Motorcraft filters, Mile Marker manual hub locks w/ESOF (No hub "floating"), AIH delete, Rust-Oleum bed coating, Silverstar Ultra headlamps w/ clear headlight assemblies, 5,000K LED interior lamps; Moog greaseable u-joints, ball-joints, front hub assemblies; retractable bed hitch, original black CPS (BEST "mod" I have), Energy Suspension bushings, Red Heavy Duty ELC, Edge Evolution 15001 (for gauges), Walker BTM, Donaldson AIS
01f25073 is offline   Reply With Quote
