Tire temperature
Question for all you tire gurus. My fifth wheel has ST215/17.5 tires rated at 4850 pounds at 125 psi on 8000 lb axles. I keep them at 115 pounds (according to the Goodyear tire inflation chart that equates to 4490 pounds carrying capacity) for a slightly softer ride. According to my infra-red temperature gauge they are at 82 degrees cold at 115 psi. After an hour of driving on the interstate at a steady 60 mph the temperature goes up to 120-125 degrees. If one side has also been in the sun while traveling that sides tires will read in the low 130's. Is this an acceptable temperature range?
Thanks, Jim
2000 PSD F-350 XLT Crewcab dually. BTS tranny, 4 position chip (stock, high idle, 60 hp safe tow & 80 hp economy), 3.73 with Mag-Hytek cover; AFE Stage II intake; MBRP 4" exhaust; EGT, tranny temp & boost gauges; HX oil line, gridheater delete plug, ccv mod, PacBrake, external coolant and tranny filters, J&J Stainless running boards.
