What size floor jack to lift front end? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
Sponsored by Discount Tire Direct
Old 07-20-2009, 08:19 AM   #1 (permalink)
tperk100's Avatar
What is the minimum weight capacity for a hydraulic floor jack needed to lift one front wheel of a TD 6.0 L F350 for purposes of changing a tire?
04 F350 Lariat, ExCab, SRW, 6.0, LOADED Shorty
SCT SF3, MBRP Turbo Back 409, Max AC Assist
DieselSite Coolant Filter, OilGuard Bypass Filter
Fumoto Drain Valve, HFCM Separator Drain Plug
50 gal TransferFlow, Sliding Cargo Bed
ScanGauge II, GlowShift EGT, Boost, Fuel Pressure
Front Receiver, Warn 8000 lb (Draw Bar Mount)
WeatherGuard Lo-Siders, MacNeil Floor Liners
Galaxy DX95T 10 Meter w/ CB Mod, Wilson 5000
Kimber SS .45 cal UltraCarry w/ LaserMax!
Frame Mounted Safe,
Empty Weight with 80 Gal Fuel 8400 lbs
tperk100 is offline
Old 07-20-2009, 08:57 AM   #2 (permalink)
My Photos: (60)
Minimum to physically lift it would be 2 ton. You will find it much easier if you get a jack with a full length handle rather than the lightweights you see very cheap with a handle 18-24 inches long. I have a cheapie and it lifts mine fine, although mine is probably 5-600 lbs lighter on the front axle than yours. I wish I had a 3 ton with the full length handle.
If you want to be sure weigh the front axle and divide by 2.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 07-20-2009, 09:26 AM   #3 (permalink)
I like my Arcan 3 1/2 ton low-profile jack from Northern Tool. It's relatively cheap ($150), made in the USA (I think, could be wrong, though), and seems sturdy (110#). Occasionally Northern Tool offers free shipping on orders over $100, which will save you $65.
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
webshots
RD97 is offline
Old 07-20-2009, 04:48 PM   #4 (permalink)
I have one of these. MTF Equipment sells and services Hein-Werner floor jacks I wouldn't want anything any smaller.
444-4D is offline
Old 01-20-2010, 02:56 PM   #5 (permalink)
tperk100's Avatar
Thanks guys. Bought a 3.5 t from Northern.
Frame Mounted Safe,
tperk100 is offline
