wheels - offset / backspeace ? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
Sponsored by Discount Tire Direct
Old 08-02-2009, 04:45 PM   #1 (permalink)
revdog's Avatar
time for new tires. and figured id like to go to a wider wheel like a 9 or 10. the whole off set thing is confusing to me. backspace is another question. can someone explain this to me so i get the correct wheels. i currantly run 325/60/20s on a stock 06 250. tires look a little big for the truck so im either going to do a icon leveling kit or a 4.5 lift. have not made up my mind on wheel diameter as of yet. 17 -18 -20. i know the tire diameter will be 35's. realy like 37 but regearing is expensive, and the truck is pushing it now with 35's. any insite or recommendation would be a big help- also pics of similar set ups. thanx in advance. also whats the offset and back space of a stock 20?
revdog is offline
Old 08-03-2009, 01:35 PM   #2 (permalink)
Feedback Score: 3 reviews
Stock I belive is 6" offset doesn't matter only back space.
Cary
caryt is offline
Old 08-04-2009, 05:02 PM   #3 (permalink)
Discount Tire's Avatar
Offset is where the backside of the mounting pad is located on the wheel from center.
For Example:
If you have a -12mm offset on a 9" wide wheel, the mounting pad would be 12mm towards the back of the wheel from the center. If you have a +12mm offset on a 9" wide wheel, the mounting pad will be 12mm forward from center. Back spacing is the measurement from the back of the mounting pad to the back side of the wheel. Click the link below for additional information
Wheel Offsets
Low Prices! More Choices! FREE Shipping!
At The Store: www.discounttire.com
To Your Door:www.discounttiredirect.com
Sales and Technical: 1.888.459.4080
Found a Lower Delivered Price?
Useful Links:
Tire Size Calculator
Current Promotions
Wheels & Tires 101
Discount Tire is offline
