Will 285/65/20s fit a stock F250??
Just bought an 08 F250 SD 4WD. Ditched the stock Wrangler AT/S tires for a set of 265/75/20s Bridgestone Dueler AT/Revo 2s. They ride much better, but look really small on the truck......not sure if it is the more conservative sidewall, but the tires look really NARROW on the truck........
So if I take 'em back to Discount Tire, what should I run? Can I upgrade to a 285/65/20 BFG AT on stock suspension (not leveled) without rubbing??? (how will those wear on a large truck, load range E? I've had them on a bunch of Jeeps, and they wore like iron, but my last 3/4 ton Chevy had them in a Load range D and they wore out QUICK! Not sure if from the lighter load range, or what....)
Please let me know ASAP.
Thanks, Ben
2011 F250 CC/SB 4WD Lariat 6.2L
Reason: Corrected size for replacement tires
