03 excursion 6L DOOR AJAR LIGHT??? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 02-03-2010, 02:16 AM   #1 (permalink)
ok puzzled as to how my door ajar LIGHT is staying on (and running board lights) along with all the dome lights......frustrated.. please help (sigh)
mattdug is offline
Old 02-03-2010, 11:26 AM   #2 (permalink)
Check the 'barn doors'. That switch likes to act like the doors aren't closed tight. Many times the doors aren't closed tight enough. That is the problem I usually have that causes this.
Hope it's that simple.
-2000 7.3L Excursion Limited. 2WD. White with tan. Hellwig rear anti-sway bar. Bilstein shocks. Rear air bags. 185,000 miles.
2000 VW New Beetle TDI
2005 VW Passat TDI...totalled
2006 VW Jetta TDI
DR.billZ is offline
Old 02-04-2010, 08:04 PM   #3 (permalink)
The X has 6 door ajar switches, and they're all integral with the latch mechanisms inside the doors. One switch in each of the side doors, and two switches in the rear liftgate (one each side). There are no switches in the barn doors (there are no wires routed to those doors).
Many have reported good luck resolving the problem by spraying copious amounts (floods) of WD40 inside and onto the switches. I tried that on my '01, and the problem resurfaced a few weeks later. I eventually replaced all six switches on my '01 with later model switches. Later model switches are packaged in plastic bags while the earlier are packaged in small boxes.
FWIW, my '05 X has not (yet?) exhibited the dreaded door ajar syndrome.
Hoowasat is offline
Old 02-05-2010, 12:17 AM   #4 (permalink)
aewsome, great info!
hey DR.billZ and Hoowasat.. really appreciated the input on the door ajar deal.
i honestly had no clue how beneficial this site was when i first sign up. you guys are great. i will be here for life.
thanks.
Matt
mattdug is offline
Old 02-05-2010, 11:39 AM   #5 (permalink)
I had the same problem with my X 2001 psd
I kept having to clean and spray the door ajar switches. It would usually work for a while. The real solution for me was..............
Replaced the rear door lifting struts. Apparently when then got weak, which they were, it made a difference. After installing the new lifting struts I have not had a "door ajar" light since. More than 1 year and running.
MARCSPSD is offline
Old 02-18-2010, 10:51 AM   #6 (permalink)
If the barn doors aren't closed tight it won't allow the lift gate to close all the way.
Guess that is what I was getting at...
2006 VW Jetta TDI
DR.billZ is offline
Old 02-21-2010, 08:47 AM   #7 (permalink)
I bought a door ajar switch for my 99 F350. Dumb question, where the heck does it go? I looked all over the door for a little plunger switch.
1999 F350 7.3 PSD
6 inch lift
Edge Evolution
6.0 Trans Cooler
ejrejr is offline
