2001 Headlamp Switch Broke - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 11-10-2009, 06:45 PM   #1 (permalink)
2001 Headlamp Switch Broke today. Just broke where the plastic shaft joins at the knob.
Do I have to replace the entire assembly?
Or can I go to a used parts yard and hope to find a similar switch and just salvage the switch instead of the entire assembly?
How does the assembly come out of the dash?
Thanks in advance for the help.
220,000 miles and still going strong.
My Daily Working Truck - 200,000 miles, 2001 X Wedgewood Blue, 4x2, Rancho 9000s, K & N Air Filter, Helwig anti-sway bars front and back, Weathertech catch-all rear mat, window vent shades, Molded mud flaps, Pioneer XM Radio, Escort 8500 Passport Radar Detector, Pioneer in-dash CD/FM/AM changer, SCMT (It Rocks!), Michelin LTX M/S 285/75 16 RD, Badged, Super Bright Back-up lights, Sylvania Silver Star Headlights, Thule roof rack system with Evolution Carrier Box, Extended Arm Rests
jpbrake is offline
Old 11-14-2009, 03:40 PM   #2 (permalink)
kick?
jpbrake is offline
Old 11-15-2009, 11:02 PM   #3 (permalink)
jpbrake,
I am in the same boat, my nob broke off a few weeks ago. I have found the whole switch assembly at Your Premiere Source for Ford Truck Parts and Accessories for about $65. I am going to see if I can find the nob at a junk yard.
steve
2000 7.3L PSD Excursion
4" MBRP 409 Turbo Back
Hellwig Swaybar
Isspro EV, Overhead 3-Gauge Mount
300K and rolling right along
Ford AIS
6.0 Liter Tranmission Cooler
BoilermakerSteve is offline
Old 11-16-2009, 09:49 PM   #4 (permalink)
I have a new headlamp switch assembly. Dealer wanted $266. I bought one on Internet for $45.
So, now how do I remove the switch assembly?
jpbrake is offline
Old 11-16-2009, 10:02 PM   #5 (permalink)
klhansen's Avatar
My Photos: (169)
With a radio removal tool (about $5 from Wally World), remove the radio. Push the u-shaped tools into the holes along the side, push the tools away from each other slightly to unlatch the radio and pull out.
Then remove the two screws at the top of the radio opening.
Then grab the dash panel and pull it loose. You'll probably have to disconnect wiring connectors before you can get it all the way out. There are red keepers on the headlamp switch connectors that you'll have to slide to unlock the connector.
The headlamp switch snaps into the dash panel from the back (or maybe it's held on by screws - can't remember exactly.)
Replace switch - plug wiring back in - replace keepers - replace dash panel - replace screws - replace radio - go for a drive (with headlights).
Hard or no-start? Check Here
klhansen is offline
Old 11-17-2009, 07:36 AM   #6 (permalink)
clamgulch's Avatar
Mine fell off years ago. I sanded down the back side of the dial (the rim) enough that I had good penetration of the plastic shaft into the back side of the knob, then I superglued it on. Problem solved.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
Old 11-19-2009, 04:02 PM   #7 (permalink)
Radio is the other side of the steering column.
I took a very thin, small flat screwdriver and slipped in the small indention under the lower center of the headlamp switch assembly. That depressed the bottom clip (there are three clips).
It came out gently. Then just swapped wire harnesses the pressed the whole assembly back in.
Took no more than 3 minutes.
jpbrake is offline
Old 11-24-2009, 11:59 AM   #8 (permalink)
I had an OASIS run on the X prior to purchase at 104K miles. The report showed the only previous owner put a full 100K mile Ford ESP on it.
For all that money guess what they replaced? Yup, one head light knob!!! I've since replaced that one with one from a Tuarus, much better design. The plug was the same.
Did a little bit of research a couple years ago on the matter and found Ford recalled the head light knob on the Excursions but for only one month. Want to say they had to have a build date of 10/99 to be covered. This of course was while ago and they could have added more months since then.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited triple pod
00 BMW 328CI 2dr silver fully loaded
65 Mustang 289 V8 4brl
69 GTO 400 4spd
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
