Ok, I have read every thread I could find. Looks like about 25% say they rub on a stock excursion and 75% say they are fine. The 285 I am looking at has a section width of 11.47 and an overall diameter of 32.6
I have just over 100k on it so assuming the stock springs havent sagged a ton....Will they fit or not ?
I've been running Bridgestone Dueler AT Revo's on my 4x2 for years and they've never rubbed anywher under any circumstances.
285x75/16's
__________________ TurboDave, EWCS(SW)USN Ret H&N Turbo 6 Racing
Seviervile TN A MAN AND HIS TRUCK, IT'S A BEATUFUL THING 01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum chip (original owner) 86 GN (original owner) 87 GN (second owner) 08 Honda Accord EX-L
I run 285x75x16's but I have X codes up front which gives me a height of 40 1/2 "at the front wheel well dead center of axle with truck on level ground. I get a small rub ONLY in full lock backing out of my steep driveway to level street. Its only for a second and I can't figure out where its rubbing but I'm not worried about it either and its only done it in reverse and not all the time.
I've run 285 75/16 tires since the truck had 12,000 miles on it with stock suspension. I just recently upgraded the springs on the truck. With new BFG A/T's the tire would slightly rub the spring on both sides with the steering all the way to lock. This was with stock wheels. Since I changed to aftermarket wheels the rub went away.
__________________ 2000 PSD Excursion Limited owned since new, Mickey Thompson Classic II Wheels, V Code Springs Front, Modified B Code Springs Rear, Rear Hellwig Sway Bar, 3 Autometer Gauges On The Pillar, DP Tuner 40hp tow, 80hp tow, 80hp Econo, 140hp Extreme, High Idle Tune, Custom 4" exhaust and muffler, Custom Tranny with TCS 3 Disc Converter, K&N FIPK Intake, Garrett GTP38R Ball Bearing Turbo.
I have Michelin 285/75/16 E LTX AT2 tires and the only issue I had was a slight rub on the ford mud flaps and a tiny bit on the drivers side fender liner. I fixed it with a heat gun, I heated the liner and massaged it with a hammer. all fixed.
See my sig. I have them on my X and 350. They rub now and then on my X when jumping a curb. But not enough to be concerned about. I am very happy with them.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
Thanks to everyone !......got my new 285's today.......no rubs yet on stock springs. Also gave it a fresh 15 qts of Rotellla synthetic and filter and a grease job today. Had to replace the batteries on Monday......first morning below freezing here.......the truck is happy and I am ready for winter.
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, Isspro EGT/Boost/ Trans temp.
1997 4runner,5spd,TRD supercharged,Bilsteins,H&R coil springs front and rear
1968 roadrunner,383,4spd
1970 roadrunner,383,4spd,pistol grip,58k 0riginal miles
1970 Charger,383,4spd,pistol grip,my first car
Congrats!!! I plan to swap in "X" springs and F350 blocks on mine this weekend and then hopefully before the end of the year I can put some new tires/wheels on it. Since 285/75r16 fit yours on stock springs I may try for some 285/75r17s.
Boomboom, you have 40 1/2" measuring from the center of the front hub to the edge of the fender in front? I think my front end is stock, but I only measure 22". Your over 18" taller than stock?
I bought my truck used, I assume its stock, maybe I'll post some pics of it and the front spriings and you guys can tell me.
2001 Excursion Limited. Tymar air filter. Marineco Mod, Oil change ball valve. FOR SALE.
Been running 295's on both the F250 and Excursion for quite a while with no issues.
What I found odd though is slight rubbing when I got new rims and Ravo 265's. The rims must be wider than the other aftermarket set or the GARBAGE Ravo's are wider. Good thing I got the four rims/tire, lug nuts, and center caps for $200. They combo had 200 miles on them.
My next mod may be X springs and air bags for the X. Finaly did the Helwig and it sure was worth the money.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited triple pod
00 BMW 328CI 2dr silver fully loaded
65 Mustang 289 V8 4brl
69 GTO 400 4spd
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
Sorry I meant measuring from the ground up to the wheel well with the tape passing by the center of the hub
Yeah.....need to get them downloaded from the wife's camera and posted. Will try to get to it this evening
Here are the pics...Sorry I didn't have time to wash it.
