285/75R16E options? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 02-13-2006, 09:53 AM   #1 (permalink)
285/75R16E options?
Who else, besides BFG, makes a 285/75R16E? I've decided to stick with the stock rims and go with that size tire.
Any suggestions? Thanks in advance.
Len
2002 Excursion PSD Limited, 4X4, Aspen Green, Cortex Tuner, Walker BTM, under-cubby gauges, Bilstein shocks, Ford finned diff cover, Hellwig Sway Bar, and BFG LT285/75R16E tires.
coldpizza is offline
Old 02-13-2006, 12:22 PM   #2 (permalink)
ArchitectandBuilder's Avatar
Re: 285/75R16E options?
We have had 285 Goodyear Wrangler MTR's on our rigs for years. Got over 40,000 on mine at this point and will be getting the same shoes again.
Barrett
Mine: 2003.25 F-350 Lariat CC, SRW,8' bed, 6.0, Torqshift, Toreador Red, Tan Leather, Trailer Tow, Rhino-Liner, Dee-Zee Platinum Box, Adjustable Pedals, Heated Seats, 6 Disk Changer, DVD, 04 Keypad, AIC, 20% Tint, Escort 8500 X-50, Magellan Meridian Color Gps, BFG 285r17 KM2’s. DPPI Dual SS Turbo Back Exhaust,"X" Springs,Issopro EV Pyro,Trans,Boost,Oil Temp, Water Temp, Volt Meter, Air Press., Viair 550C AC, 26" & 29" Hadleys, 2006 Front End, Chrome Tow Hooks, Warn 16.5ti, Billet Cummins Killer Badges, Int. VT-365 Badges.
Diesel_Mom's: (Redhead): Goodbye 2001 EX, Thanks for 4 years. Brand Spanky New 2005 Eddie Bauer Excursion, DVD, Toreador Red</font> , 6.0L Powerstroke, all options including (3) children, (1) 95# Golden Retriever, Goodyear Wrangler 285 MTRs.
ArchitectandBuilder is offline
Old 02-13-2006, 03:53 PM   #3 (permalink)
Looks like Toyo makes one. Anyone have experience with the Toyo M55??
Maybe it is pricey.
Len
Old 02-14-2006, 02:31 PM   #4 (permalink)
Since the Bridgestone Dueler A/T REVO in 285-D is only 3% below the rating of a set of E's and both are significantly above the GVWR/GCWR of the vehicle, I don't understand why it has to be an E rating.
//bruce
2000 Excursion Limited V10 4x4
ART brakes, Rancho RSX shocks, Hellwig rear sway bar, SD grille, V10 badges, Sylvania Silverstars, clear corners, and Bridgestone Dueler A/T REVO 285s.
rozett is offline
Old 02-15-2006, 10:26 AM   #5 (permalink)
For pure load ability, it does not have to be an E. The D's have softer sidewalls, and that leads to less stability but a softer ride. Like most of life, it's a compromise.
boatpuller is offline
Old 02-16-2006, 11:37 PM   #6 (permalink)
Nitto makes that size and wt. code and can be purchased for $129.00 w/no shipping from National tire and wheel.
Check it out.
'02 Excursion LTD, Superchip, Valvoline 5W-40 Blue Synthetic, K & N filter (not kit), Evans Coolant and 203deg. stat, dual alt hose replacement, Trans-Go kit and billet torque converter, KYB Mono-Max's, Hellwig rear bar, '03-'05 axle bump stops.
'99 Triumph Trophy. Platinum
delta2565 is offline
Old 02-17-2006, 12:38 AM   #7 (permalink)
A1980GMC's Avatar
I just bought 285/75R16E tires from Discount Tire Co for cheap. $550 out the door.
Their an off brand. Dominator or something like that. I went cheap cause I plan to add ym lift soon and then I will be getting new rims and tires.
So far so good. I like em!!
A1980GMC is offline
Old 02-17-2006, 12:22 PM   #8 (permalink)
I was thinking about the same thing....Getting some 285's....
I had been running some 265's from BFG [Long Trail]...ride was nice, but they were to soft, and the tire wear life was short [25k]
Recently switched to Michelin's 265's [LTX] loaded rated E, which I need for towing [#3400 rating]....so far so good....
My question is???
Will the 285's fit stock rims, without causing distortions????
I think the wider tires would like better on the SUV "SOW"
I mean, a BIG PIG needs "BBIIGGGER" tires!!!
XS_SUV
Graupp is offline
Old 02-17-2006, 04:59 PM   #9 (permalink)
My Photos: (20)
Check it out.
The Nitto LT285/75R16's only come in D rating. The only E rated tire I seen from Nitto is the LT265/75R16E's. The only LT285/75R16E's I seen are the BFG AT Ko's,Toyo M-55's and Interco TrXus Mud Terrain's.
jogiba is offline
Old 02-17-2006, 05:00 PM   #10 (permalink)
A1980GMC's Avatar
I'm running them with no problem. Hell they were cheaper than 265's
I thought that I might have a little rubbing but none so far. I haven't tried yet [img]/ubbthreads/images/graemlins/smokin.gif[/img]
A1980GMC is offline
Old 01-12-2012, 11:23 AM   #11 (permalink)
wally392's Avatar
our x had been stock 265's, then recall put 265 e range on, then went to 305 d range.....bigger tire....but ride was "loose", i attribute to less ply on side walls, went back to 265e for firmer ride,....very close to a new set of shoes too,....been reading reviews and the 285 75r16e seems like a great choice if staying with stock rims. any non-believers?
Heck...I'd rather walk than drive a chevy!
2002 7.3 X 4x4 Ltd
1994 Bounder (Tailgate Machine)
1979 Wellcraft Scarab 300 (just sold - dang that boat was fun!)
wally392 is offline
Old 01-12-2012, 03:04 PM   #12 (permalink)
I've got Toyo 285's on my X-the Open Country model-love them! Good tread-not too load-great wear!
Mark
1 PSD 4x4 Custom Tow Vehicle-the 550
1 PSD 4x4 SUV-the X
2 PSD 4x4 Duellies-F350&F250HD
42' HillsBoro 23K Dbl Duellie Goose
32' Open Triaxle Dovetail
22' Gooseneck Dump
34-5Y Prowler LSI Fiver Loaded with Xtra Stuff
Oooops-almost forgot,
1 PSD 4x2 Chassis Cab-the E450
SuperDutyFiver is offline
Old 01-12-2012, 04:45 PM   #13 (permalink)
Revo II is available in 285/75-16 E rated. Finally. Put some on over the summer.
Yes, I know this is an old thread, but it's still current info.
Old 01-14-2012, 09:18 PM   #14 (permalink)
LTX A/T 2(On-/Off-Road All-Terrain)
Michelin, they ride great and after 40,000 miles they look great.
charliev is offline
Old 01-14-2012, 10:23 PM   #15 (permalink)
texaspsdx's Avatar
Changing from 265 to 285 has the effect of changing your gear ratio. Going to 285's, your effective ration will change from 3.73 to 3.55. If you tow heavy loads like I do, you will notice a difference. Just something to keep in mind. I still run 265's and have change to 4.10 gears. Love towing with the 4.10 gears.
Ron
2000 Excursion Limited 2x4, 4.10 w/Detroit TrueTrac, PSD/Auto, ATS turbo shroud,Badging, 4" exhaust w/AeroTurbine 4040XLL, AIS, HX crossover, ISSPRO gauges/A-Pillar, SuperChip 1705, Pre-Pump & In-Tank Mod, Banks TransCommand, ZooDad, Baldwin Oil ByPass, Ford AIC, F350 rear springs, Helwig Rear Sway Bar, Michelin's LTX MS,
1983 Avion 34V - 35' travel trailer,
Hensley Arrow No Sway Hitch
texaspsdx is offline
