4X4 Issue - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 05-12-2009, 01:40 PM   #1 (permalink)
4X4 Issue
I have an 02 Ex and am having the following problem withmy 4wd
When I engage 4wd, I get an indicator light that its in 4wd as it should, and on dry pavement the front end grabs. But once i get on the sand, I have no front end traction at all. I need to lock in the hubs in order to run in 4wd. I believe it may be a vacuum issue as the defroster kicks on when i turn the switch from 2wd to 4wd.
The hubs are new and function, and the dash displays 4x4 which i guess means the relay works so how do I go about vacuum testing the system?
Thanks.
Btw, I have limited tools, knowledge, and patience
blasko is offline
Old 05-12-2009, 01:43 PM   #2 (permalink)
purplehorn1977's Avatar
get a smoke machine is the easiset way other wise you can be there for a long long time and never find it. the leak that is. or just say to hell witht the auto and get out and lock it in that what i do on our trucks that way i know they are engaged.
2004 Crew Cab shortbox 4x4 lariat
4 inch exhaust soon to be 5
zoodad mod
AutoMeter Autolite II Gauges
SCT x3 programmer with spartan tunes
Real courage is found, not in the willingness to risk death, but in the willingness to stand, alone if necessary, against the ignorant and disapproving herd. — Jon Roland, 1976
purplehorn1977 is offline
Old 05-13-2009, 10:02 AM   #3 (permalink)
Thanks.
Not sure about the limited knowledge part; stating that the defrosters come on with the 4WD is a BIG clue.
Yes you have a major vacuum leak
There is a scheduled service required at 60 or 70K on the front hubs and includes new vacuum seals [I have had a set hanging above my work bench since 70K now at 110K ] I think the part number is F81Z-4A322-AA also at one time there were instruction on this site or a related one on how to do the service and what grease to use and NOT to use and so on.
If someone can tell us where this link is I need to print it out as well!
You could pull the hose(s) off the axle then plug them then turn on the 4WD if the AC is on and not the defrosters the leak is in the axle.
If it still goes to defrost then you have a leak between the valve on the right inner fender and the axle.
It should not be that hard to find it not like it is under the dash or hidden in the body some place.
I would bet that it might be the hubs.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 05-13-2009, 07:12 PM   #4 (permalink)
MotionMan's Avatar
The 4x pump runs for 45 sec, then stops, if there is a leak you will loose the 4x then, I ditched the air system but yours is a little different since the defroster comes on, yours is most likely outside of the axle.
2003 7.3 Excursion Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, Top Gun Bumper, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. PIAA Lights, Toyo 325/60/18s on Chrome Alum rims.http://community.webshots.com/user/stellinm
MotionMan is online now
Old 05-14-2009, 09:22 AM   #5 (permalink)
Mine did the exact same thing and it was the vacuum solenoid mounted on the passenger side fire wall under the hood, ford dealer said it is very common for these to go out, it cost me about 70.00 and it was very easy to install, I think it was two bolts and 3 vacuum lines total.
2003 Excursion, 6.0, 4X, everything stock.
2 Trucks, 1 Motorcycle, 3 Dogs, 1 Cat, 1 Bearded Dragon, and 1 Wife
DieselSteve2008 is offline
Old 05-14-2009, 10:44 AM   #6 (permalink)
Send a message via Yahoo to keith_1963
Mine is doing the same, except I don't have any problems with heater controls. I will have to check the selanoid. I also have the problem that I cannot turn my hubs manually, even putting vice grips on them, so I bought the rebuild kit to lube them, I hope that's the issue.
2001 Excursion Limited. Tymar air filter. Marineco Mod, Oil change ball valve. FOR SALE.
keith_1963 is offline
Old 05-19-2009, 09:49 AM   #7 (permalink)
Thanks for all the replies. I will test the system with the info given. I really appreciate all the help.
blasko is offline
Old 05-19-2009, 09:08 PM   #8 (permalink)
i can't bleve it -- this happend to me this weekend on my 02 -- i am leaning on ditching the auto hubs for a set tof manul warns i dont trust anything vac to work inportan stuff
but i could be jated with the problems with my gm heating /cooling stuff
1986 jimmy Buggy (RamJetGMC) 350RamJet th400 203ORD205on 42” tires d60/14bolt all locked and 200' of dom tube the offroad truck <img src="/ubbthreads/images/graemlins/wink.gif" alt="" />
2002 X 7.3 tow rig Excursion Limited Ultimate mods Green air filter, 3 gage pillar install,Tru-Cool Max TR cooler,FS-2500 Bypass Oil Filter coolent Filter,WW,tag,X overhose,X-code springs,F350 blocks,Banks 4" Monster Exhaust, AIC,programer, CB-cobra, Fumoto valve & a flux Capacitor <img src="/ubbthreads/images/graemlins/wink.gif" alt="" />
http://community.webshots.com/user/ramjetgmc
RamJetGMCaol.com
Zapped277 is offline
Old 05-19-2009, 10:25 PM   #9 (permalink)
i went with the milemarker's in stainless steel.
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
