Old 03-16-2006, 09:05 AM   #1 (permalink)
6" lifted 2wd X pic
Finally got my Christmas gift installed...
man, talk about a better ride, Pro-comp did good and no effect on mpg, either. I like it!
Kirk Allen Jorden
broncokirk is offline
Old 03-16-2006, 10:45 AM   #2 (permalink)
Mudraga's Avatar
Re: 6" lifted 2wd X pic
That would be "Big Mamma" lookin guuuud! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
I didn't know you were on here Kirk! hee heee!!
-Alex
2002[1/02] Excursion 4x4 Ltd. PSD,Unknown chip/program, K&N GenII FIPK Air Filter, straight pipe exhaust, Autometer Z Series pyrometer and boost gauges, Air Lift SuperDuty air bags with Load Controller II onboard air system, Sonnax Tricumulator, HX hose.
Mudraga is offline
Old 03-18-2006, 06:05 AM   #3 (permalink)
Looks great. Where did you purchase it from? And did you install it or have someone else do it? If someone else did it how much did they charge and how long was your truck in the shop for?
As you can probably tell I have an Ex i'd like to lift.
Again it looks GREAT!!!!
Doug
2000 Excursion 2WD. Superchips 1705 tuner. Bilstien shocks. Hidden front hitch. 295-75r-16 tires.
ddavis263 is offline
Old 03-24-2006, 07:56 AM   #4 (permalink)
Doug,
Sorry it took so long to reply, had problems signing in. The kit was installed by 4 Wheel Parts, took them 2 days (I have done plenty of lift kits myself and decided to let someone else have the fun this time...nice). The total including install was @ $1600.00 (the kit alone is @ $1100.00), this is with the 4 side steps, too. Yeah, and I do like the looks of it, also I can now get under the X and change my oil (sat too low before and I did not want to lose any weight to do it). Later.
Kirk
Old 10-30-2006, 11:12 PM   #5 (permalink)
I am considering having 4 Wheel lift my 04 EB X.
Questions?
Are you still running (2 months later) the original tire/wheel package. I may go to the 35's as suggested, but I would like to get more miles out of the current set?
Did you block the rear end or use the add a leaf? They tell me the add a leaf will stiffen the ride (OK to an extent), reduce the sag (need this) and lessen the need to beef up the rear sway bar.
2004 EB X 6.0 2WD, everything except 2nd row caps and 4WD, 6" Pro Comp, Hellwig rear sway bar, 285-65/20 BFG KO, Air Raid intake in factory box, MBRP cat back 4", 30% tint, color match splash guards, Prodigy, Sirius
popups4rent is offline
Old 10-31-2006, 02:09 PM   #6 (permalink)
Mudraga's Avatar
Questions?
I'll answer for him since I don't think he watches this forum except when he wants to know something.
1. He was running the stock 265's. And yes it looked funny. [img]/ubbthreads/images/graemlins/tongue.gif[/img] He was planning on going with 295/75s like I have on mine. I don't remember if he got them yet or not. On stock 265s, his 2WD w/6" lift was about 1 1/2" higher than mine on 295s with stock springs (I think they are Superduty springs though, not stock Ex).
2. I think he went with the add-a-leaf. It does stiffen the ride, but not as much as with lighter vehicles. I'm not a fan of add-a-leaves, but on the Ex they aren't too bad.
Mudraga is offline
Old 11-01-2006, 09:51 AM   #7 (permalink)
TheCraftsman - How has your Edge performed? 4 Wheel Parts says it is far better than just adding gauges because of the defueling features and auto truck off after the EGT is down. Has it caused you any warranty issues?
Thank you for the info. I did not realize this was my 1st post, as I have fixed a few bugs off of this site.
Old 11-01-2006, 05:20 PM   #8 (permalink)
Mudraga's Avatar
Mine doesn't have any of that nifty stuff like the shut down etc. Mine is the Edze EZ. Its basically just the 10k mod that you can find on this site if you do a search. The truck runs pretty good with it on there, but if I really get on it, it sets of the SES light every time (very annoying). And the throttle is quite touchy off idle. Riding down my street, its a challenge not to give the passengers whiplash as my street is quite bumpy and my foot tends to bounce a little.
As soon as I can find some funny money I'll be ditching the Edge EZ in favor of an SCT Xcalibrator with a couple of DP Tuner tunes on it.
Mudraga is offline
Old 11-20-2006, 11:52 AM   #9 (permalink)
Which of your pics is with the 295's installed? This is one option I am look at. Specs say the 295 should not go on these rims though.
Old 11-21-2006, 10:41 AM   #10 (permalink)
Mudraga's Avatar
These are 295s on stock rims:
My Ex
Mudraga is offline
Old 11-21-2006, 02:34 PM   #11 (permalink)
Good look, any wear issues with these? I do not have a lead foot, just tow a lot.
Costco will not put them on my truck for liability reasons, 4 Wheel Parts will for $800.
From Discount I can go with 20X9 rims and Nitto Terra Grapplers for $2000.
Old 11-22-2006, 10:34 AM   #12 (permalink)
Mudraga's Avatar
Well, I don't know how many miles the BFG AT K/Os have on them because they were on the truck when I bought it and haven't been able to contact the PO. The truck has 76k on it now, so assuming the PO replaced the stock tires at 40k, then I'll probably only have about 40k on them when I replace them (they're getting close now). Obviously this is pure speculation. He could have put them on at 10k for all I know. He was a "moder" and did make some changes to the truck so he may have ditched the stock tires early. I don't know.
But since I've had them, they seem to be wearing fine. I don't tow much but I have towed up to about 8-9k with them and they're very stable. Road noise is very low. Wet traction is great for the most part. Haven't really gone off-road per se, but I've honestly never liked the BFG ATs off road anyway. I'm going to be replacing them with my X-mas bonus this year. I was thinking of giving the REVOs a try since they come so highly recommended on this list. But they don't come in 295s. My wife likes the 295s so I'll probably grab another set of the K/Os.
Mudraga is offline
