I have n't read any that have done it. but its possible. The parts should bolt in. The under floor vent (ie under the carpet vent) needs to be changed to one from a crew cab manula..My Excursion has a manual 6spd convertion, trans is from a 2007.5 Dodge. Its a G56. the previous owner had a nv4500 5 spd in it.. On the diesel truck resource there is a guy who is converting his ford superduty to a nv4500 etc. I thought i read amemeber here had a excursio nconverted the manual already..it was white ..maybe in the for sale section..??? that is the only one i have seen besides mine that is a manual trans
deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
I think BTS does this for trucks as well. May want to contact them. Maybe in the end it would be cheaper
I converted mine. I haven't done a write up and I owe a couple people e-mails and phone calls on how to do it. Ive just been totally swamped at work rite now.
10" lift, 38" tires, ORU Cross over steering, ORU Ajustable track bar, Afe intake, Magnaflow 4" exhaust no muffler, Dp f5 mod stock, 60 tow, 80 econo, 120 race, 140 extreme, Swamps 175/146 stage one injectors, Auto Meter boost and egt gauges, and an empty wallet
yup you were the member I had remembered doing it. when you get a chance. sanp some pictures..etc.. Did you use a manual crew cab under rug floor vent?
Thanks,
Deo
I never got around to putting the floor vent back in. It still works though because the carpet is molded for it to fit underneath so there is still a passage for the air to travel lol. I have some pictures in my for sale thread i think. Let me know if you want some others.
