Old 05-01-2004, 11:36 AM   #1 (permalink)
ABS light comes on
my ABS light (anti-lock brake system) comes on and usually right before the brakes kind of rumble slightly or slip a little like it does if your comming to a quick stop. it goes outwhen you shut vehicle off(resets itself i guess.) but comes back on frequently. this is a 2000 X 2wd. are there any tsb's or recall info.
2000 excursion superchips progamer,(ole ladies ride) no fuel milage increase but the power is there.
2000 f250 4x4,hypertech tuner ,no kitty,4in exhaust turbo back , air raid filter
97 f350 psd, c/c, 4x4,3.55ls, 285/75 goodyear MT/R's
shimmed w/ calif. kit, 10k mod, ported snorkel,hypermax downpipe,ps2000 propane
45hp superchip,pcm code TDE1, TEXAS TROPHY HUNTERS decal!!
ATE MY KITTY !!!!!!!!!!!!!!!!! looking for hunting opportunities in the north mississippi area or s/w tennessee, deer and hogs , let the littles ones walk
missplaced texan is offline
Old 05-03-2004, 07:33 AM   #2 (permalink)
Re: ABS light comes on
I had the same problem on my 2000 2wd. After posting the problem on the forum and getting several very good suggestions I did the following:
Cleaned the front ABS sensors - just turn the wheel to full stop and you can reach the sensor, remove the sensor, clean and reinstall. Turn wheel to full stop in the other direction to do the other side.
Replace VSS Vehicle Speed Sensor, it is located on the third member on the L/H (drivers) side, it takes about 10 minutes after you have the X jacked and supported. The sensor costs about $20.00. I tried to clean this sensor, but it didn't work.
Good Luck
Vettmike
Mike
'00 White XLT with PSD Badging, K & N Filters, PPIII
vettmike is offline
Old 05-08-2004, 04:16 PM   #3 (permalink)
i used a scan tool and pulled code p 0603( which is powertrain or internal control module KAM test error) any other suggestions the stealership said more than likely it is the anti-lock control module. im going to try and check the vss sensor and the 2 front brake sensors tommorrow when im off. also i just installed a program w/ my superchips tuner the day before so is maybe this code have something to do w/ the new program installed and not have a thing to do w/ my abs light.
Old 05-04-2005, 01:07 PM   #4 (permalink)
whatever happened with the KAM error? I am getting it right now.
No Boundaries '01 PSD - U codes, Rancho 9000's & stabilizer, SCMT, Isspro EVA trio on pillar, BFG 285's, badges, Fabtech Desert Guard, PIAA 580 driving and pencil beam, dome override, ART brakes.....
edex2 is offline
Old 05-04-2005, 07:56 PM   #5 (permalink)
Got my answer on the KAM error. The mechanic fixing the speedo problem says that the KAM error is tripped anytime the computer is tampered with by a performance chip. In this case the chip is the SCMT. He confirmed that it is 'harmless' and can be generally ignored.
My abs light is coming on and blinking from time to time and they are telling me it is the whole module that has to be replaced.
edex2 is offline
