Old 03-07-2005, 01:38 PM   #1 (permalink)
Adding Trailer Brake Controller to and Excursion
I have an "01" Excursion and have not looked yet but I'm wondering if it has the auxilliary plug under the dash to plug in a trailer break controller into like my "96" did. If so, does anyone have a pin out wiring diagram for this connector?
*KEEP ON STROKIN*
96 F-350,4x4,CC,PSD,255,000 miles and growing,5 speed,285/75/16 Dominator AT's, 4.10's ,US Gear Chip, Open Air Air Filter, regulator shimmed, KAT gone with a straight pipe,WD Downpipe, WD Pyro and Boost Guages, Air intake ported, EBPV Disconnected, Custom Ranch Hand bumper front and rear, Warn Manual Hubs, Pioneer CD player.. POWERSTROKE!!! GOTTA LOVE IT!!!!!
2000, VW Jetta, 1.9 liter Turbo Direct Injected (baby Power Stroke) 136,000 , K&N Filter,50+ miles per gallon, really gotta love that....
Gone with the Ex 2001 Excursion, 100,000 miles bone stock
Justin B is offline
Old 03-07-2005, 03:05 PM   #2 (permalink)
rock_doctor's Avatar
Re: Adding Trailer Brake Controller to and Excursion
Yea it is there but you will have to look with a flashlight because it is hidden behind a dash support (directly under the radio). You can see it though a hole that is stamped in the support. The truck came with a pigtail to hook into the controller you should try to get the pigtail from ford (F81B-14K122-BA) or from a trailer supply dealer.
From the pigtail documentation:
Brown wire is listed as illumination
Dark Blue wire is listed as trailer brake feed (to trailer)
Red is listed as trailer brake control feed (power to controller)
White is ground
Light Green is stop lamp feed to brake controller
Now the sticker that came with the controller has two ford color codes listed, Ford and New Ford. We use the "Ford" listing so it may be the exact same as your 96.
Let me know if you need anything else.
mark
2005 Excursion w/ 6.0L PSD
rock_doctor is offline
Old 03-07-2005, 07:21 PM   #3 (permalink)
Here is an easy way
Scroll to the bottom of this page on the left
http://www.brakecontroller.com/
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 03-08-2005, 09:11 AM   #4 (permalink)
Absolutely if you can get the pigtail life would be much easier! Just make sure you solder all the connections.
mark
Old 03-08-2005, 03:45 PM   #5 (permalink)
mark
Buy the controller from the above and that adapter plugs into the truck AND THE controller no solder required!
Wish they had that when I got mine or they did and I did not see it but I think that the made for your truck wire is a new thing
Bruce
Under Construction
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
Old 03-08-2005, 06:11 PM   #6 (permalink)
I see on that page that they have a controller that reads air brake pressure. Does anyone make an aftermarket product that reads the hydraulic brake pressure? I gather this is how ford's "tow control" unit works.
2004 Excursion EB 6.0 Estate Green. As yet, unmodified. Delivered 2004-07-14
Zaphod is offline
Old 03-14-2005, 01:19 PM   #7 (permalink)
My Photos: (10)
Master brake makes the best but is expensive but worht it. It is called Brakesmart. comes color of dash and installs in about 30 minutes.
j_apetersen is offline
