another thread concerning V code front springs and shocks
just got hold of a set of V codes off of a f-250, have read several threads and did searches regarding shocks,
i want to do this swap all in one day so i need to know any info i can,
with the V codes it can raise front end about 2 inches per the threads i have been reading, i am assuming the stock shocks will no longer fit, i need new shocks anyways, and from my reading i can NOT use stock F-250-350 shocks because they mount differently for the front shocks, are the rear shocks the same, i will probably be adding the f350 blocks in the rear to keep the foward rake i have and will also be adding the hellwig sway bar
so my question is, what shocks for the front and rear for the additional 2 inches of lift, what has been the experiance with differnt shocks, they do not neccesarily have to be of the adjustable breed, truck never has been taken off road, mostly highway driving, have a set of 305/70/16 on it now and clearnace not an issue, just looking for a little more stance and better handeling
part #'s would be appreciated, even have seen kits with dual shocks, any input on this
thanks
glenn z
1978 bronco XLT ranger, 4x4, hopefully soon to be an IDI candidate
1939 ford coupe, 351 cleveland supercharged, 33 x 19.5 mickeys out back, 700 + HP
Re: another thread concerning V code front springs and shocks
I have V code springs and Bilstein shocks but they are the stock height replacements. They fit OK but seems to be just a little short when fully extended (when I was hanging the new springs) the shocks were the limiting factor by about 1/2". But the lifted shocks are too long and you would have to put longer bumpstops on so the shocks wouldn't bottom out. I think there is more of a chance of the longer shocks bottoming out. My V codes settled down alittle. I used to be alittle nose high with a full tank of fuel. Now with a full tank I put a level on my running boards and it is level. I only got about 1 1/2" of lift. But my stock springs were new only had about 10,000 miles on them. IMO I think dual shocks are a waste of money and will ride way to hard. Your stock shocks will work but I would still replace them. When I first put on my Bilstein shocks I thought they road alittle hard but I love them now I think they softened up alittle or I just got use to them. Ken
2002 Excursion Limited 4x4.Black,BTS Trans,ATS ported shroud,AIS,SCMT,SPA gauges,Magnaflow super tuner exhaust,Bilstein shocks,V codes,Hellwig swaybar,Radius Rods,AirDog,CCV3550,JNB fuel mods, Weld EVO Renegade 16x8,Nitto Terra Grappler AT 305/70/16 E Code=NQW5,ART brakes.
I'm ditto with Dentman,as I have V codes,Rancho 9000X shocks and rear F350 blocks also.
The stock shocks will work fine with the V's but for a better riding suspension upgrade them with aftermarket shocks like Rancho's or Bilsteins which are both very good models [img]/ubbthreads/images/graemlins/smile.gif[/img]
The V code springs enhanced the X's handling much better but a rear Hellwig if you don't already have a rear sway bar will put the finishing touch on the handling issue.
BILL
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
Just so I get this straight, the conversion is simply "v code" springs from the front of F350 and the rear blocks from the same. Add on the Bilstiens or what ever shock you choose and you net about 1 1/2" lift front and rear? I have access to the blocks and springs that are NTO's from a friend of a friends off road shop and think this would work out great if I understand it right.
IN MY DRIVEWAY:
04 4X Excursion 6.0 Black,Limited, everything except 2nd row captains & chrome tubes, Weld Commando 16x8 wheels, 305/70/16 Nitto Terra Grapplers, 4 1/2" ProComp leafs front, 04 B-Codes with 5 1/2" tapered block in rear, 30mm rear sway bar, Billet badges & fuel door, Superduty Harley Grille, C'Btr mirrors, XM SkyFi2.
05 Fleetwood Prowler 300BHS Travel Trailer, Reese WDH with dual cam sway control
Looks like you got it covered.
If you friend would like to sell another pair of the tappered F350 blocks and bolts I would sure be interested. Im in Southern Calif. Thanks, Ken ken527@excite.com
The V codes will give you 1.5". The 350 blocks will level it but you may want a little rise out of the back or with a full tank or a trailer you will be draggin a$$. I used an add a leaf for 3" and a 4" block for the rear. The block came from a chevy. I have not seen any settling of the front and it has been 3 months now. Watch the 350 block you get, I gave a pair away to a board member and it ends up these had no taper to them. It looks like long box CC don't have the taper due to length. You can see the taper with your eyes so look close.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
talking to the guy i am getting these springs off of and i am kinda confused, he said they are off of a 2003 F-250, but they had the highest spring rate of 8800 LBS, the door code read VP and by what bruces chart reads there isn't even one there listed at 8800 LBS, i think he may be reading the total GVW rating on truck.. what do you all think... the 2003 springs should fit on my 2000 X correct...i have him looking at the casting number on the spring, if it is a V code it should be a 2C34 number and if it is a 2C3Z it is an x code...
I go off of what the white VIN decal states the springs are,mine came off of a fresh 2002 F250 and it had "V" for the front set.
The casting numbers are very very inconsistent so I recommend not trusting em.
8800 sounds about right for the F250 [img]/ubbthreads/images/graemlins/smile.gif[/img]
You are correct you have V code front and P code rear
Not sure what a P code is as that info is at the office and I can not find the link to it though I think I have listed it here a while back.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
Me too! [img]/ubbthreads/images/graemlins/smile.gif[/img]
John [img]/ubbthreads/images/graemlins/cool.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
