I know you all have heard the tire questions over and over...I apologize up front.
I've lifted the front of my X with W code springs with a home-made "leveling kit" comprised of an additional long leaf from the rear Excursion spring pack and two shorter leaves ala DR. It rides well and I like the firmness without it being too harsh. Crazy thing - the wife likes it too! The front wheelwells sit at 41 3/4" on a set of borrowed 285/75-16s.
I'd like to put on the tallest tire I can mount with minimal rubbing with the current lift - I expect a little rubbing at the spring and I plan to move the bumper out a little also. I'm eyeing the old Buckshot Radials (Coyote tread pattern) in 305/85-16 or getting a set of some other brand's 315/75-16s. I've used the Buckshots before on my Ramcharger (3 consecutive sets) and liked them. I prefer the tall skinny tire look. Do you all think they'll fit (and I take the chance and order them) or should I just go with the 315/75s?
Awaiting your opinions.
Ty
2004 4X4 Excursion XLT 6.0L Black, intake elbow, straight pipe, modified W and B code springs
1945 Ford GPW
1973 Jeep CJ5 350, NP435/TeraLow geared Dana 20 and lockers
1988 Dodge Ramcharger 360, NP435/241, D60s, 37s
1963 Dodge M43 Ambulance
7.3L IDI project engine
Nobody touching this one! Okay, let me re-phrase. How are you all with 315/75-16s doing for clearance and how much lift do you have? I intended to run the 305/85-16s on a narrow rim with close to or stock offset to keep them within the wheelwells.
1945 Ford GPW
I think the 315/75-16 are about the equivilent of a 33-34" tire, right? I was running 35-12.50-17 with a DR 4.5" lift and had a slight rub on the leafspring (trimmed the front plastic valance). My buddy is running 315/75-16 tires on his F-250 with a Fabtech 3.5 leveling kit and rubs the front leafs a little.
Hope that helps?
__________________ SteveO
Lemon Lawed back to Ford on 2-25-2010
04 4WD Excursion
315/75-16s are approximately equivalent to a 35-12.5-16 and measure out at between 34-35" depending on the brand. How's the clearance at the rear of the front wheelwells on your Ex and your buddy's F-250?
1945 Ford GPW
315/75 always is aprox. 34-35" doesn't matter if its a 12" rim or a 20" rim. If you raised the front 4+" ya can run a 35"...might rub in sertin situations.
cary
Oops,Reminder...don't post after a few beers [img]/ubbthreads/images/graemlins/grin.gif[/img] Dam metric system...think in inches and the posts metric!
Cary
I had a 2003 F250 SC Long bed that I put a Donahoe Racing 3 inch level lift on the front and used F350 blocks on the rear and ran a 315/70 R17 and had very minimal rubbing on the inside of the front leafs in reverse at full wheel lock. FWIW
Very minimal.
2003 E350 7.3L Extended Cargo - No Windows - Dipricol Optix: Pyro, Trans, boost - Walker BTM - Bellowed Up-Pipes - DP Tuner No Start, Stock, 60T, 80E, 120 Tailgaters special - Spectra Premium Fuel Tank Hutched & Harpooned (Ford Tank delaminated), Dual CAT Pre-pump Filter Setup
2003 GMC Sierra 2500 6.6L LB7 - Cognito UCA's, Bilsteins, Powdercoated H2's on 315 BFG AT's, PPE Standard
1993 Ford F250 7.3L "Black Beauty" 278K miles & is used to take the dogs out to play. Mods: 8,000lbs of Dog Hair.
SOLD: 2003 Excursion Limited 7.3L Mineral Gray 4x4
Very minimal.
Thanks for your observations, this helps.
1945 Ford GPW
