Any thoughts on this inverter? It is 1500 watts, Xantrex from Costco for $84.99. I also found it on the following site. I was thinking of mounting it under the 2nd row, but how do you hide the wires? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
What are you intending to use the inverter for mainly?
The price looks good from Costco and to run the wiring to the battery I'd slit a small hole in the carpet and run it done the drivers side channel to the firewall,others have done other routes but that's the first I'd do.
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
Thanks for cleaning up the link. I would use the inverter for some tailgating (TV and possibly microwave) along with some back country camping. I do have a pop-up camper with a deep cell battery to keep the lights going in it.
2002 X, 4x4, Limited Ultimate, 285 Dueler A/T Revos, Bilstein shocks, Edge mini-spring pack, F-350 4" rear blocks, Street Scene speed grill, Lund trim color bug deflector, Hellwig rear anti-sway bar, tinted front windows, Fram Sure-Drain
Please PLEASE use the UUB link in the post window and not the whole entire URL. This thread is so wide I had to get up and walk across the room to see the whole thing. [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
This inverter will probably handle what you are wanting to do. Xantrex is a very good company that manufactures some very high quality stuff. This inverter of theirs at Costco however,is not a sine wave inverter,meaning it is very hard on delicate electronics. Don't run a TV, computer, DVD etc... that you care to much about off of this type inverter, cuz it's life expectancy is greatly reduced. Bottom line - Yes it will work. Don't use your favorite laptop !
Houndog
Thanks for the warning. Just took that particular item off my christmas list to Rachel.
Barrett
__________________ Mine: 2003.25 F-350 Lariat CC, SRW,8' bed, 6.0, Torqshift, Toreador Red, Tan Leather, Trailer Tow, Rhino-Liner, Dee-Zee Platinum Box, Adjustable Pedals, Heated Seats, 6 Disk Changer, DVD, 04 Keypad, AIC, 20% Tint, Escort 8500 X-50, Magellan Meridian Color Gps, Goodyear Wrangler 285 MTR’s. DPPI Dual SS Turbo Back Exhaust,"X" Springs,Issopro EV Pyro,Trans,Boost Guages, Under Dash Pod, Viair 550C AC, 26" & 29" Hadleys, 2006 Front End, Chrome Tow Hooks, Warn 16.5ti, Billet Cummins Killer Badges, Int. VT-365 Badges.
Diesel_Mom's: (Redhead): Goodbye 2001 EX, Thanks for 4 years. Brand Spanky New 2005 Eddie Bauer Excursion, DVD, Toreador Red</font> , 6.0L Powerstroke, all options including (3) children, (1) 95# Golden Retriever, Goodyear Wrangler 285 MTRs.
Barrett just make sure you don't remove anything off the Harbor Freight & Craftsman lists [img]/ubbthreads/images/graemlins/wink.gif[/img]
I've been checking into inverters and I'm going to get one at some point too. I'd like to add that there are TWO types of sinewave inverter: Modified and Pure. Modified has the tops and bottoms chopped off the sinewaves and does to your sensitive electronics what clipping does to your stereo speakers. Ouch. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Pure sine wave inverters are exactly what the name implies, pure sine wave. That is what you need for SENSITIVE electronics, like laser printers. I don't know what it takes to run a TV or Microwave though. [img]/ubbthreads/images/graemlins/confused.gif[/img]
Pure sine wave inverters are spendy...
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
That one is a little bigger than the one I've got, but I've had good luck with mine mounted on the flat area in the cargo compartment besides the passenger side window. It takes an extension cord to reach it when using it going down the road, but it's in a pretty much perfect spot for tailgating.
Just my .02
Regards,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
clamgulch,any resources on the web for affordable sinewave inverters? I'd like to upgrade from my weeky weeky 700 watt continuous inverter [img]/ubbthreads/images/graemlins/wink.gif[/img]
2004 E/B Excursion, 6.0 PSD, 4x4 in Oxford White, Born on Date: 2/13/04, 3.73 L/S, Transfer Case Skid Plate, 4x4 Trailer Tow Grp, Cargo Pkg, E/B Premier Grp. Thanks to Al "G" @ Tomball Ford.
Thank you thank you thank you for the link RPM! [img]/ubbthreads/images/graemlins/cool.gif[/img]
The wife and I are shopping for an solar energy system for next year and they have some nice packages [img]/ubbthreads/images/graemlins/smile.gif[/img]
I do want to nip this little error in the bud. It's actually the opposite. Intuitively, you'd think that delicate electronics would be sensitive to less-than-perfect sine wave inverts --- it makes sense. However, this is yet another case of intuition being wrong.
Laptops, TV's ... even most radios will be happy with this inverter. These devices actually, internally, operate on DC and the AC to DC power supplies are such that the quality of the inverter is a non-issue. Even desktop computers will tolerate as much as 1/2 second power _interruption_ before having a problem. Occaisionally cheap electronics (mostly radios) will have problems due to the interference of the power's harmonics with the amplifier circuit... but this is rare with modern electronics --- you'll find it mostly with older things. Older electronics tend to have transformers and rectifiers whereas newer electronics tend to have some form of switching power supply (or a combination of transformer and switching supply). Switching supplies actually _prefer_ square-ish wave power.
The things that will have the most problem with square-ish-wave inverters are the simple things --- motors, mostly. They have no electronics to filter the power, so they can react badly. This means blenders, power tools.... even the motor in the microwave (although likely not the electronics) can react badly.
Reacting badly can range from making more noise to turning backwards to not turning at all.
All is not lost, tho. Add a length of extension cord (thicker the better, too). The "capacity" (ability of the copper in the cord to store small amounts of electricity) of the cord "rounds" out the corners of the square waves making them more acceptable. 20 or 30 feet of large guage cord can make even the worst power acceptable to the most picky motors.
