Anyone had this problem? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 12-25-2008, 10:51 AM   #1 (permalink)
detroitfd's Avatar
Started truck in am at 3 degrees, not plugged in, started and ran fine for about 40 minutes (got a run at work). Came back and left to go home, 2 blocks later truck hesitated a few times then died. Cranks like crazy but won't start.
I noticed my DP tuner switch had no power, so took chip out in case that was problem. After removal, still no start, and now no WTS light.
Ford hasn't found problem yet, but says fuses are blowing and the CPS power/communication is not working. Anyone know what this might be?
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, Decel, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ S&B conical filter - Zoodad mod - Suncoast Extreme Duty Trans rebuild w/ TransGo Shift kit, Amsoil synthetic ATF & Magnefine inline filer - BD Triple Disc Billet Torque Converter - 4" Stainless Steel Turbo Back (4" down pipe) Magnaflow exhaust - ATS Turbo housing and 4" intake sleeve - Turbo Master Wastegate Controller - HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter w/ CAT ELC coolant - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge cluster face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub - 4.5" LED marker/turn lights in front bumper - ViAir HD onboard air system w/ 380C compressor, 2.5 gal tank & Grover stutter tone air horn - FireStone RideRite suspension air bags -
TOWING:
2004 Dutchmen 31BH travel trailer
detroitfd is offline
Old 12-25-2008, 11:28 AM   #2 (permalink)
Check the #30 fuse. Unplug the fuel heater at the back side of the fuel filter bowl. The #30 fuse powers the PCM, and wait to start light. The fuel heater could be shorted.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
HighwayPrisoner is offline
Old 12-25-2008, 08:25 PM   #3 (permalink)
detroitfd's Avatar
Thanks! How much are fuel heaters/are they hard to replace?
Jerry
My PSD X
TOWING:
Old 12-27-2008, 04:15 PM   #4 (permalink)
detroitfd's Avatar
Ford called and said it's the fuel heater assembly. $609. Can't seem to find a part matching that online anywhere, but that seems like a lot for that?
Jerry
My PSD X
TOWING:
Old 12-27-2008, 04:26 PM   #5 (permalink)
klhansen's Avatar
My Photos: (169)
Don't let them touch another thing, pay them off and get that truck the heck out of there. Just leave the fuel heater unplugged, replace the fuse and drive away as fast as legally possible.
You can get a replacement fuel heater for a bit over $100. If you can change a fuel filter, you can replace the fuel heater element. Pull the filter, unscrew the center post (LEFT hand threads), remove the fuel heater element and replace.
F81Z-9J294-AA
Int’l 1831196C92
From what I understand from another member's experience, the Int'l part will look different from yours, but installs the same way and works fine. Might have been a redesign to eliminate your type of failure.
Hard or no-start? Check Here
klhansen is offline
Old 12-27-2008, 07:45 PM   #6 (permalink)
MotionMan's Avatar
Thats great advice, try to remember to buy Int parts, they can be up to 1/3rd off OEM. I have it memorized now, saved $100 on a CPS and this one has over 100,000 miles on it.
2003 7.3 Excursion Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, Top Gun Bumper, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. PIAA Lights, Toyo 325/60/18s on Chrome Alum rims.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 12-29-2008, 01:35 PM   #7 (permalink)
detroitfd's Avatar
I called the dealer today and spoke with the service rep. He said what was being done was replacing the fuel heater, + 1/2 hour labor for that, + the 4 hours they wanted to charge for the initial diagnosis time, totalling $609. I told him that I called the diesel tech there after checking here when 3 people said it was the heater and fuse.
They did tell me that the 4 hour labor would go towards the repair, so the way I figure it, at most, I owe them about $360. I found the Ford part # listing at $150. So with 1 hour install and the part, at most I should be paying $250. I could see them hitting me for the 4 hours labor at most tho. Some have mentioned perhaps going over the dealer if I don't get what I wanted there. Anyone know whom I should contact?
Thanks!
Jerry
My PSD X
TOWING:
Old 01-02-2009, 09:38 PM   #8 (permalink)
detroitfd's Avatar
Well, met w service manager and got him from $610 down to $400. Still too much, but much better. Sheesh. Heater element and fuse for it.
Jerry
My PSD X
TOWING:
Old 01-03-2009, 07:23 PM   #9 (permalink)
Man, their diesel tech sure is a money maker for them. Does He really know what he is doing, or conveniently burning up the clock. It seems, he is a clock sucker, drawing all the time he can. The customer sure takes a beating. At least, your are good to go for now.
SLAPS Member
Old 01-03-2009, 09:35 PM   #10 (permalink)
fwbkent's Avatar
Thats why they call it a stealership. Dont blame it all on the grease monkey.Service writer and managers are thiefs also.
1997 CC LWB 176,000 miles. Tymar intake,Diamond Eye exhaust turbo back, gauges. DP Tunes.
2003 E 550 17 ft box van. Stock for now.
fwbkent is offline
