Old 08-14-2008, 12:12 AM   #1 (permalink)
Anyone running U and P code springs?
I am looking forward to upgrading my stock X springs to something Super Duty. I have been looking for some V's and B's, but just found a good deal on some U's and P's from a 2003 F250 CC FX4.
From what I have read, the U's have a little less capacity than V's and the P's have more capacity than the B's. I plan on following Cary's recipe for rear spring packs so I can keep my towing capacity and improve my ride.
Is anyone running a set of U's and P's stock or modified? If so, what do you think?
Thanks!!
2000 Excursion LTD 4x4 PSD 186k stock for now
1995 PSD F-250 2WD XL SuperCab LB super-beater, stock, AT, 180,xxx miles and climbing
steelsoldiers is offline
Old 08-14-2008, 09:59 AM   #2 (permalink)
IMO the V codes are the min. I would use on the front. Do you have any additional info on the P's..
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is online now
Old 08-14-2008, 12:11 PM   #3 (permalink)
Can a U code be modified with a leaf or two from the stock D springs to make them ride more like a V?
The P's are rated at 6830 according to this post: Rear Leaf Springs..
Old 08-14-2008, 05:39 PM   #4 (permalink)
I recently put U codes on the front of my 2000 diesel excursion (because I got them for $50 for the pair on craigslit). My old springs had 100k miles, and the U codes were said to have 13k.
They raised the front 1 3/4 inches on the passenger side, and 1 7/8 inches on the driver's side.
I would have preferred to put on V codes, but for the price I couldn't pass it up. If you are getting a great deal on the U codes, go for it, it's well worth the upgrade - nicer drive, especially on speed bumps...
I have not done anything in the back yet...
-Gabe
gabeyd is offline
Old 08-15-2008, 01:13 PM   #5 (permalink)
I haven't tried the P's but based on the weight ratting I would think they would be stiffer and ride harder than B's modded or not. My mod has you replacing the thin spacer-shim and replacing them with the 1/8" ones from the Ex springs. This allows more flexibility and a softer ride. The addition of the 2 short Ex bottom springs to the B codes just gives a height change and IMO doesn't affect the ride quality. If you want to try the P's I would replace the thin shims with the Ex ones. You may or may not need the 2 extra leafs with the P's.
Cary
2006 Yamaha FJR1300
caryt is online now
Old 08-15-2008, 01:39 PM   #6 (permalink)
What about using one leaf from the stock X D-codes and adding it to the U-codes? Could you cut the spring wraps off of the ends and use it like an add-a-leaf?
The P-codes might be worth trying since a lot of my highway time is with the back of the X loaded with luggage, tools, baby toys, a chocolate lab, etc...
Old 08-15-2008, 09:40 PM   #7 (permalink)
bpcheramie's Avatar
Leave the lab at home and give it shot. If the price is real good what do you have to lose??
Brent
01 Excursion 4X4 - DIY Injectors, Garrett GT38R, DI Regulated Fuel Return, HX CrossOver, AFE stage II, Diamo 17 Karat 18x10.5 w/ 325x60x18, 4" straight pipe exhaust, DI 6 position chip, X and F Springs with F350 Rear Blocks and .....................
01 Excursion 4X4 - RIP 2/22/2008
All work has been done by Diesel Innovations!!!!! Thanks to MR POWERSRTOKE RACER for all the help.
bpcheramie is offline
Old 08-26-2008, 01:37 PM   #8 (permalink)
I decided to hold out for a pair of V's and B's. The price wasn't good enough just to try the U/P combo.
Old 08-26-2008, 07:58 PM   #9 (permalink)
Us will be fine in the front I am not sure of the P code and how it compairs to the B and F I would look into it.
The difference between the V and U up front is about 3/16" of an inch, most Xs sit about 1/4" low on the left due just more heavy stuff on that side, drivers controls and spare tire. the AC stuff on the right is just full of air and a few small motors.
As you can see I have one U code on the right front and a V on the left.
The Left still sits low and that is b4 I get in.
Does anyone know how the P compairs to the F?
Have you looked for the info on the P?
I know the A, B, and F are well documented here if you can find it.
Look under CaryT and my name in your search
I would not discount it just because it has not been tried but then I was the first to use Vs up front as far as I know.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 08-27-2008, 07:22 AM   #10 (permalink)
Bruce, you were the first to use V codes up front in a X and we are all very happy you did! Others including myself just built apon your work.
Thanks, Cary
2006 Yamaha FJR1300
caryt is online now
Old 08-27-2008, 12:19 PM   #11 (permalink)
OK did a litle more looking and the P code should be a possibility
Links to more info on rears and lots more links: B and F Code Data!
From the above :
The B's are 320/670 and the F's are 334/776 any one have the dual rate numbers for the Ps?
Not sure I ever posted what I did or "over did" to my F codes:
I added the third leaf up form the old G code X rears ala "boertje" "F-code modifications-another way" But I also added the second leaf up and the rear sits a little high and it could be softer.
I have had some very heavy loads on the rear and about all they do istake it a bit below level (I am talking Pintle hitch here with no WD hitch)
I am thinking of removing what was the second leaf up and is now my bottom leaf and see what I get. Also I do not have the overload from the F code installed but I do have the original X Anti-Wrap installed with clearance between the rubber bumper on it and the spring above.
Still think the U-V combo up front works out great and would do it again.
Under Construction
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
Old 09-03-2008, 07:08 AM   #12 (permalink)
Thanks for the added input, Bruce. That makes me feel a little better about giving it a try. I will give the guy a call back and see if he still has them. If not, then I'll keep up the search. Anything would be better than stock!
Old 09-04-2008, 01:24 AM   #13 (permalink)
U's will be fine, once I did the V's I found it to be higher than needed, & there are a few guys who did go with U's back in 2005.
My Photos----- BTS BUBBA "Life Member"
2002 7.3L Excursion 4x4, FTVB, MBRP 4" SS Exhaust, Rancho 9000X shocks, "V" code Front Springs & "B" Code Rear Springs, Ride Rite AirBags, Rear Hellwig Swaybar, Cut Front BumpStops, DieselSite Ext Trans Filter Kit - Coolant Filter Kit & 203 stat, "Scotpart" mod, "Hutched & Pooned", "LandYot" Radius Rods US Gear Overdrive 75mph @ 1750rpm's
2001 7.3L F350 CC LB 4x4 5" Exhaust, pillar guages, BTS Trans, US Gear Underdrive, DP 6 pos chip, V10 Trans Cooler, DieselSite - Coolant Filter Kit, Evans Coolant, 203 stat, DI reg Fuel Return, GT38R BB Turbo, AFE 2 Intake, Banks Intercooler, Air Rite Bags,
2000 Excursion Limited V10 4x4 7" Lift
"Family of 5 saved by Grace"
Snowman269 is offline
Old 09-04-2008, 12:19 PM   #14 (permalink)
aklim's Avatar
I'm running U fronts and A rears because they were a freebie. Great price. It did pump up the rear by 1 3/4 and about 1 1/4 in the front. Works better than the stock Excursion springs.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, Van Turbo and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 09-05-2008, 11:20 PM   #15 (permalink)
I found a set of V/A springs today for $75. I think I'm going to give that a shot. I have a set of 285 Nitto Terra Grapplers ready to go on. I still need to get my thicker rear sway bar and shorter bump stops for the front.
