Old 05-14-2004, 03:55 AM   #1 (permalink)
ART rotors installed
I just finished the install of ART rotors all around on the Excursion. What a difference! No more vibration!!! I wanted to let everyone know about there service. I dealt with Pad. He was very friendly on the phone, and very exact. Everything I asked for he repeated a couple times to confirm it was right. I gave him a tight time frame and he came through. I recieved the rotors, but one of the front rotors was missing. UPS lost it!!!! I called Pad right away. He took care of me and sent me another rotor at no cost. He sent it 3 day air because I needed it for a trip. He ate the shipping charges too. He provided tracking numbers everytime. Great place to do buisnes with! And the rotors are BEAUTIFUL!!! They can be a little hard to get a hold of on the phone. But whenever I left a message, it was returned within 30 minutes. I am also going to post this is fordtrucks.com so other people can read about there service. Thanks Pad!!! [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
2000 Black Excursion,PFC 2 piece rotors,Tipton tuned,BDP stage 2 singles, BDP H2E, AFE stage 2, Spearco 7.3, ITP Reg. return fuel system, Evans, BTS, 186,000 miles....And still goin' strong! Thanks Beansdieselperformance.com and Puredieselpower.com for all your help
BBBxcursion is offline
Old 05-14-2004, 09:43 AM   #2 (permalink)
Re: ART rotors installed
I have his rotors and pads they are a great and solved my vibration(wobble). Just a word of caution. When you get new tires or have them balanced or rotated. Re torque the lug nuts your self if some one else does it they will screw it up and your vibration will come back.
Ken
2002 Excursion Limited 4x4.Black,BTS Trans,ATS ported shroud,AIS,SCMT,SPA gauges,Magnaflow super tuner exhaust,Bilstein shocks,V codes,Hellwig swaybar,Radius Rods,AirDog,CCV3550,JNB fuel mods, Weld EVO Renegade 16x8,Nitto Terra Grappler AT 305/70/16 E Code=NQW5,ART brakes.
ken527 is offline
Old 05-15-2004, 03:25 AM   #3 (permalink)
Thanks for the tip~!
Old 05-15-2004, 09:00 AM   #4 (permalink)
Do you have a cost break down?
2000 Excursion. Super Chip, 4" exhaust,K&N Filter.
Remington is offline
Old 05-15-2004, 03:39 PM   #5 (permalink)
jimhoff's Avatar
I'm just about to replace my front rotors with the $59/pair eBay ones--couldn'd afford fancy ART's or Frozen Rotors. I'll post how they are. Any tips on front rotor job? How to lube caliper? Torque method? Should I bleed or flush the system?
2008 F350 XL Reg Cab 4x4, 5.4, 15,000 mi on 5/08. Blizzard 810 plow, Polycaster spreader.
2000 Excursion 4x4, 7.3, 176k mi on 5/08. Some mods but nobody cares (;
2007 Edge AWD, 5k mi on 5/08.
2001 Honda Rancher ATV 4x4, plow, 3,400 mi on 5/08.
jimhoff is offline
Old 05-18-2004, 08:07 AM   #6 (permalink)
Yes, please post! I'm getting some pretty major front end shake when braking...I know those rotors are warped. From what I understand, turning will only help for a little while, because the alloy used doesn't withstand heat very well?
Since you got yours from ebay, can you PM me a link? I'd like to take a look at what you bought. $59 sounds like a great (ok, better than great!) price if it fixes the problem and it stays fixed.
Thanks,
Michael
2001 Excursion PSD Limited 4x4, SCMT Max Tuner, Diesel Innovations 4" exhaust, 3 pod A-pillar w/ VDO Vision boost, pyro & Trans, AIC, Baldwin bypass filter, ATS Ported Compressor housing...See my mod pictures HERE!
1995 Camaro Z28 K&N FIPK, Throttle body Airfoil, Jet-Hot MAC Headers, Borla SS 3 exhaust /w bypass, 3.5" Aluminum driveshaft, 4:10 Gears, B&M Ripper shifter, Accel 300+ ignition, Accel SpiralCore wires, Shift light, 100hp Nitrous [img]/ubbthreads/images/graemlins/crazy.gif[/img] <font color="red"> FOR SALE! </font>
2002 32' Keystone Bobcat 294BHS travel trailer
PSDExcursion is offline
Old 05-18-2004, 09:10 AM   #7 (permalink)
I've seen some rotors listed at local auto parts stores in the $80-$90 range. Not much more than the $59 eBay rotors when you figure in some shipping.
When I replaced my rotors, I sold the old ones to someone on the East Coast. Cost ~$70 to ship all 4 and pads.
jschira is offline
Old 05-19-2004, 05:05 AM   #8 (permalink)
jimhoff's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...category=33564
is the link. eBay username is erotorshop. They were easy to put on and work like stock. I did the fronts only &amp; no pad change and the shimmey is gone. $59 plus $30 shipping plus additional $60 Alaska shipping is still the cheapest deal for me. Shipping was fast. I've put 200 miles on them and so far so good.
jimhoff is offline
Old 05-19-2004, 08:19 AM   #9 (permalink)
Ah ok. I'm thinking since the OEMs warped, if I bought another set, I'd just be setting myself up for the same experience again. I've also heard of other folks getting the ART rotors and never having a problem again. I like to fix stuff once! [img]/ubbthreads/images/graemlins/tongue.gif[/img] Anyway, I checked prices, both ART and Frozen Rotors.
The following prices are for Excursion rotors, slotted with new pads:
ART $350
Frozen Rotors $464 (Shipped)
Don't know about the shipping costs with ART, but I think $30 is probably a safe number. Since I tow, I know there's a fair amount of stress being placed on those front rotors. Mine warped after towing in the rain, and have just got worse. Heck, I could put a jug of milk in the front and have a milkshake by the time I got home. I think the slots in the rotors are a real good idea too, especially for my application.
Looks like I gotta save up some more dough. [img]/ubbthreads/images/graemlins/frown.gif[/img]
Michael
Old 05-19-2004, 08:27 AM   #10 (permalink)
Make sure that your lug nuts are properly torqued and torqued in a star pattern a little at a time:
50 ft-lbs.
100 ft-lbs.
165 ft-lbs.
The air-wrench monkeys at Quikie-Lubes love to run the lug nuts on in a circular pattern and run them up to 165 (or more) all at once. This stresses the rotor.
jschira is offline
