Old 07-18-2004, 05:09 PM   #1 (permalink)
Auto AC self test.
Had something strange happen today after work. Got in the X, started her up, took off. After about a minute, I noticed I was still sweating, looked down and the AC was off, pushed Auto, nothing, pushed every button, nothing. Had to stop off and get some oil in preparation for my upcoming 2200 mile towing road trip. Pulled the fuse panel cover, all was fine. Got my oil, came back out, started her up, now its working! This is all I need, an intermittently working AC on a family road trip in the middle of summer. Got home, looked at the manual, turns out theres a self test you can do to check out the system. Be patient if you try it, it took me about 6 tries to get it right. No codes by the way, hope it was just a fluke.
Electronic Automatic Temperature Control Module Self-Test
The EATC module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A scan tool must be used to retrieve these concerns.
The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to intermittent diagnostic trouble codes for concerns that occur during system operation. The vehicle interior temperature should be between 4°-32°C (40-90°F) when performing the self-test. If the temperatures are not within the specified ranges, false in-car temperature sensor DTCs will be displayed.
The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
To enter the self-test, press the OFF and FLOOR buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer going around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
If any DTCs appear during the self-test, follow the diagnostics procedure given under ACTION for each DTC given.
If a condition exists but no DTCs appear during the self-test, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Improper Operation.
To exit self-test and retain all intermittent DTCs, push the blue (cooler temperature) button. The control will exit self-test, retain all intermittent DTCs and then turn OFF (display blank).
To exit self-test and clear all DTCs, press the DEFROST button. The vacuum fluorescent display window will show 888 and all function symbols for one second. Then, the EATC control assembly will turn OFF (display blank) and all DTCs will be cleared.
Always exit the self-test before powering the system down (system turned OFF).
Intermittent DTCs will be deleted after 80 ignition switch ON cycles after the intermittent condition occurs.
Electronic Automatic Temperature Control Module — Retrieve Continuous DTCs
The EATC module will retrieve only continuous (intermittent) DTCs when carrying out this procedure.
Retrieval of continuous DTCs can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when retrieving continuous DTCs.
To retrieve continuous DTCs press the OFF and PANEL buttons simultaneously and release, then press the AUTO button within two seconds. All vacuum fluorescent segments will be displayed if there are no continuous DTCs present. Continuous DTCs are indicated by the presence of the degrees Celsius symbol (ºC) on the EATC module display. Record all DTCs displayed.
If any DTCs appear, carry out the diagnostic procedure. Refer to the Electronic Automatic Temperature Control Module Diagnostic Trouble Code Index and follow the ACTION for each DTC given.
If a condition exists but no DTCs appear, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Incorrect Operation.
To exit and retain all continuous DTCs, press any button except DEFROST. The EATC module will exit the retrieve continuous DTCs mode and retain all continuous DTCs.
To exit and clear all continuous DTCs, press the DEFROST button. The EATC module will exit the retrieve continuous DTCs mode and all continuous DTCs will be cleared.
Always exit the procedure before powering the system down (system turned OFF). Once the procedure is exited the ignition switch must remain ON for at least 30 seconds to allow the temperature blend door actuators to automatically recalibrate.
Continuous DTCs will be deleted after 80 ignition switch ON cycles after the intermittent fault occurs.
989171 is offline
Old 07-18-2004, 06:21 PM   #2 (permalink)
Re: Auto AC self test.
My 2003 Excursion has had the same "feature" several time since I bought it last year. I told asked my Ford Dealer to look at and their reply was that they could do nothing until it broke completely.
[img]/ubbthreads/images/graemlins/frown.gif[/img]
-------------Toy List Follows-------------------------
2003 Excursion, 7.3L PSD, K&N Filter, Air Lift air springs.
2004 26' Gear Box TT.
2001 Yamaha YZ426F, 2003 KX 85, 2001 KX-65
roberts80906 is offline
