Old 03-10-2006, 03:03 PM   #1 (permalink)
Mudraga's Avatar
Autometer bezel doesn't fit Excursions
I had DI order this Autometer gauge mount for me along with my new tranny temp and air pressure gauges. Well I went to pick it all up today and I decided to test fit the bezel before I bought it and I'm glad I did! It was a little too wide and the molded corners were totally the wrong shape to fit the Ex dash. [img]/ubbthreads/images/graemlins/mad.gif[/img] I didn't even know the Ex dash was a different shape than the trucks, but they tell me it is. Even if it did fit with some trimming (although I think no amount of trimming would have worked), I don't think the gauges would have fit without hitting the stock instrument panel.
SO...what to do now? I have four gauges. Two already exist in my two pod pillar mount. I can't go overhead because I really don't want to try and run the air lines up there. My brake controller is already under the cubby hole so that spot is out (although I'm considering moving it). Plus I don't like having to look down so far to see a gauge. Anyone have any ideas? [img]/ubbthreads/images/graemlins/shrug.gif[/img] Please!
2002[1/02] Excursion 4x4 Ltd. PSD,Unknown chip/program, K&N GenII FIPK Air Filter, straight pipe exhaust, Autometer Z Series pyrometer and boost gauges, Air Lift SuperDuty air bags with Load Controller II onboard air system, Sonnax Tricumulator, HX hose.
Mudraga is offline
Old 03-10-2006, 03:19 PM   #2 (permalink)
Re: Autometer bezel doesn't fit Excursions
Yup, they now make a four pod pillar mount, and I think some of the sponsors carry them.
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 03-10-2006, 04:28 PM   #3 (permalink)
4 Gauge A Pillar Mount in a X
FMT
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 03-10-2006, 09:54 PM   #4 (permalink)
Mudraga's Avatar
Paul B
Thanks thats a great suggestion. But they don't make them in wood grain [img]/ubbthreads/images/graemlins/frown.gif[/img] which is what I have right now (see pic). And I really REALLY like it becuase it matches the other interior accents. I've considered buying a new set that can hold 3 gauges, but then I still have to find a spot for the 4th and then I have an extra set of gauge pod pillars that I may not be able to sell. So I figure I'm better off just trying to find a place to put two gauges.
Mudraga is offline
Old 03-11-2006, 01:38 PM   #5 (permalink)
"Overhead windshield mount" gauge pods are available. See here for an
example.
Might be what works for you.
2001 Excursion 7.3L 4x4 XLT
Hypertech Power Programmer III, AIRAID Intake System, Poweraid, Bilstein shocks, Hellwig Anti-Sway Bar, Landyot's Radius Rods, and "Powerstroke Diesel v8" stickers.
sleepies is offline
Old 03-13-2006, 12:57 PM   #6 (permalink)
Mudraga's Avatar
Thanks for the suggestion but the air gauge is prohibiting that.
I'm starting to think my best option will be to get the 3 gauge pillar mount and just leave the air gauge down under the dash. I don't need to look at it often anyway. Thanks for everyone's suggestions. Doesn't anybody make a single gauge under cubby mount?
Mudraga is offline
Old 03-13-2006, 04:30 PM   #7 (permalink)
There is also a 3 pod under the cubby mount available that many have used
I did a simiilar mount prior to the above being available if you look at pict of my 02 you can see it. I think the one I used was for on top of a Dodge dash.
the one made for this location is better looking.
So who has one to show???
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 03-13-2006, 06:52 PM   #8 (permalink)
Bruce
Under cubby pics, see my pics.
Paul B
2000 Honda CRV EX
PIC'S
Old 03-14-2006, 04:24 PM   #9 (permalink)
I find it very hard to believe the Excursion dash and insterment area are different from SD's. EXCEPT that the SD's dash was redesigned a few years ago with the new body style, and the excursions was not. I'd double check with the vender that they got you the correct year pod before giving up on that idea.
boatpuller is offline
Old 03-14-2006, 08:04 PM   #10 (permalink)
Nope they were differnt from the gitgo!
that is why I did what I did to my 02!
Yep; another invention I did nothing with [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Under Construction
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
