Old 03-20-2003, 09:27 AM   #1 (permalink)
Aux. Front Light
Okay bought a set of Hella Black magic lights on the way home yesterday. Looking for some different mounting options, drilling the bumper or installing a pushbar not an option. Remember seeing someone's X awhile back that mounted a set of lights behind their grill, any problems with projections? Where are those dang pics (looked briefly, but forgot the subject they were posted under).
Gary
2003 4X4 LTD Edition PSD Excursion Rancho 9000's, Hellwig swaybar, U Codes,; 2001 F550 4X4 XLT PSD Smeal 6T Pump Hoist; 2001 F250 CC 4X4 XLT PSD
anoxic is offline
Old 03-20-2003, 10:32 AM   #2 (permalink)
Pharmer's Avatar
Re: Aux. Front Light
Gary,
I mounted Hella 550's behind the grill with fabricated brackets attached to the inner grill support. Take a look at pictures in the sig.
Kevin
03 Excursion Eddie Bauer 4WD 7.3L, 265 REVOS, U's and F's(mod), 3rd row headrests
68 Cougar xr7 390GT http://www.supermotors.net/vehicles/registry/3724
Pharmer is offline
Old 03-20-2003, 11:05 AM   #3 (permalink)
Kevin,
Out of all the pics I look at of folks trucks, when I see one I remember certain things, and the pic I was referencing in the previous post WAS your truck [img]/ubbthreads/images/graemlins/grin.gif[/img] I remembered the Xtree!
That was what I had in mind was to fab a bracket to attach to the vertical posts behind the grill. Any problem with the projection of the light thru the grill?
Gary
anoxic is offline
Old 03-20-2003, 12:42 PM   #4 (permalink)
Pharmer's Avatar
Gary,
No problem with light projection, but the lights should be far enough back to leave room to aim. Did you see the newer picture, it has a better view. I actually get more use out of the yellow fog lights, cheap ones out of JC Whitney mounted in the bumper. The Hella's are wired to the low beam circuit and the fogs to the parking lights. You can use the factory through the firewall wires, to hook up the lights. The are located on the drivers side of the firewall near the brake booster. One more thing, I used the horizontal part of the grill support to mount the lights.
Kevin
Pharmer is offline
Old 03-20-2003, 05:23 PM   #5 (permalink)
Shoot Shamuex2000 a PM . . If I remember right he had a set on his X at the last MOB meeting and it looked pretty nice.
Regards,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
2003 VW Jetta TDI - completely stock and 49mpg!
2003 Kubota B2910
dmftoy1 is offline
Old 03-20-2003, 05:39 PM   #6 (permalink)
Great looking Aux light install. I was trying to figure out how to mount my Hella's....now I know. Great job !
2003 Excursion Limited 4X2, 6.0, 3.73 LS, TT mirrors, Bilstein shocks
skyrider is offline
Old 03-22-2003, 07:33 PM   #7 (permalink)
Pharmer,
Okay got a question, Did you mount directly thru the bottom fiberglass surrounding the grill? Right now I have the bolts about as tight as it will go, and the lamps seem to flex on the fiberglass and vibrate [img]/ubbthreads/images/graemlins/shrug.gif[/img].
Anybody know which color wire is the high beams?
(EDIT 3/24/03) BLACK/GREEN
Gary
anoxic is offline
Old 03-24-2003, 06:52 AM   #8 (permalink)
Well got them mounted and wired yesterday. Still need to fine tune their alignment. Readjusted the lights so they would be resting firm against the grill, helped with the vibration problem. Cheated and used preexisting locations for mounting the relay and fuses. Used the mounting screws for the washer fluid and coolant tank. Mounted the toggle switch above the drivers side headlamp assembly out of the way, I really did not want to drill any holes in the dash. While I was at it, went ahead and did Steve Racers fog light mod. That has to be the most straight forward and easiest mod I have done to date [img]/ubbthreads/images/graemlins/grin.gif[/img]
http://community.webshots.com/album/58567134jSVhnF
anoxic is offline
Old 03-24-2003, 12:47 PM   #9 (permalink)
Pharmer's Avatar
The install looks good. For the vibration I cut up a hard sponge block sander and wedged it between the radiator support and the light housing. Kinda of a rig job but it works and you can't see it as the sanding block is black in color.
Pharmer is offline
