Old 02-15-2000, 03:46 PM   #1 (permalink)
Aux. Idle Controller (APCM) for the EXCURSION
Well, before I go under the knife in two weeks, I decided to try one last attempt at finding out about installing the APCM or Aux. Idle Controller on my soon to arrive EXCURSION. What I found out was the following from the two lead Electrical Engineers on the EXCURSION PROJECT. (Yes, I spoke with real live people at FORD, yet again!)
The EXCURSION does not have the connector to plug the APCM into. The connector consists of four pins that are connected to the PCM (Powertrain Control Module).
What we need to do is the following:
1. Connect the Tan/Red wire of the APCM cable to 12V Key Power.
2. Connect the Black wire of the APCM cable to Ground.
The remaining two wires are a twisted pair. (WARNING: THEY MUST STAY TWISTED EXCEPT AT WHERE YOU MAKE THE SPLICE OR CONNECTION. THESE ARE DATA LINES AND REQUIRE TO BE TWISTED TOGETHER!)
3. Connect the BUS+ Red/Blue wire of the APCM cable to the TAN/ORANGE wire from the PCM Pin# 16.
4. Connect the BUS- white/violet wire of the APCM cable to the PINK/LIGHT BLUE wire from the PCM Pin# 15.
I specifically asked if the APCM or the PATS would interfer with one another and was told that it would not and that their test vehicle has a breakout box that allows them to have a APCM.
As soon as I am healthy enough to install my APCM I will. Should be mid to late March. If anyone decides to do so before I instal my unit please post back.
Regards, and Good Luck
I forgot to add the following:
PCM connector number is C1027. I was told but have not verified that the two data lines are also available at the OBDIII connector.
The wire numbers for the two data lines are
Pin 15 wire #915 BUS-
Pin 16 wire #914 BUS+
Ordered 2000 EXCURSION on 11/16/99, Chestnut, PSD, 3.73 LS, AT Tires, Skid Plate, Tele PWR TT Mirrors, Chrome Wheels, Reverse Sen. Aid. 1/27 Serialized to be built week of ?????, Priority 01!
[This message has been edited by jbkrab (edited 02-15-2000).]
2000 XLT EXCURSION, 4X4, Chestnut, PSD, 3.73 LS, AT Tires, Skid Plate, Tele PWR TT Mirrors, Chrome Wheels, Reverse Sen. Aid., K&N Air Filter, 3 Guages, TTM, APCM, W-D Turbo Brake, Rancho RS9000's, Grover Air Horn 1609KD, Towing a 2001 Dutchmen Supreme Travel Trailer Model 31BH4-DSL.
jbkrab is offline
Old 02-15-2000, 06:22 PM   #2 (permalink)
Re: Aux. Idle Controller (APCM) for the EXCURSION
I ordered the plug last week and have the aux idle controller ready to install. I took the manual home from the dealership last week and was ready to wire it this week. I did not know about the twisted wires however. You may have saved me a lot of trouble on this install. I will let you know how it goes.
Excursion Limited, 4X4, PSD with all the goodies except reverse sensing. Ordered 9/25, DORA 10/05, Built 11/30, Picked up on 12/16. Black/TAN
Excursion7.3PSD is offline
Old 02-15-2000, 06:32 PM   #3 (permalink)
Excursion7.3PSD,
Did you order the connector that would normally be in the vehicle? If so can you post the part number? I rather not hard wire my APCM, much better to use the plug.
jbkrab is offline
Old 02-15-2000, 11:44 PM   #4 (permalink)
Hi guys,
Have either of you looked into the "fast idle control" sold by Diesel services? http://www.dieselservices.com/controls.htm
I was hoping to find an idle control that was a little more stylish than Ford's. I emailed them to see if it would work on an Excursion, thier reply:
Thank you for your request from the Diesel Services Web Site.
The Electronic Fast Idle Control will fit all Ford diesel vehicles.
Electronic Fast-Idle Control
Select any idle speed from stock through to 1800 rpm.
- Optional load-sensing control available
- User friendly, no programming required
- Soft start design, simple plug in system
- Sustains engine temperature during prolonged idling
- Faster warm-up
- Longer engine life
- Reduced fuel consumption
Should you require further assistance, please feel free to e-mail or
contact me at 1-800-667-6879, location #1..
Sincerely
Wendy Kaar
There is some discussion about this idle control in earlier posts. I, of course am just talking here, I don't have an Excursion, yet. I found out this week that mine is schedualed to be built the week of 2/28!!
tnostrant is offline
Old 02-16-2000, 07:14 PM   #5 (permalink)
tnostrant,
I contacted Diesel Services awhile back and I remember that the price was about $500. Thats why I decided to call SmokeyWrens friend at White Motor Co., Mr. Louder.
Ordered 2000 EXCURSION on 11/16/99, Chestnut, PSD, 3.73 LS, AT Tires, Skid Plate, Tele PWR TT Mirrors, Chrome Wheels, Reverse Sen. Aid. Locked 2/22, ETA 3/6, Priority 01!
jbkrab is offline
Old 02-16-2000, 09:51 PM   #6 (permalink)
JCK:
Connector was supposed to be in today. Truck didn't arrive so it will now be in on Friday. I will give you part number from the wrapper. Thanks for your info about the wires.
Regarding the other aftermarket Aux idle control. I paid a lot less than the price you stated. And it is OEM.
Old 02-16-2000, 10:42 PM   #7 (permalink)
VMAC out of Canada sell an aux. ilde control requires no cutting or splicing of wires. You unplug leads from foot throttle plug them into throttle control then plug throttle control into the truck. Basicly putting it inline with an on off switch mounted where you want it. When it's off foot pedal operates normaly turn on and it takes you to a preselected RPM
TRK4 Work: designer & consultant of emergency apparatus.
My Toy: 2000, F250, PSD, 4X4, XLT, SC, SB, Off Road Pkg, TT Pkg, Dual Alt. AIC, Line-X, Westin Grill/Brush Guard, Nerf Bars, Custom Scotchlite Striping Package, Nice Flashing LED and Strobe Lights LED, LED Tail/Marker Lights, Whelen Alpha12Q, On-Spot Automatic Snow Chains, and 03 Mirror Upgrade.
TRK4 is offline
Old 02-17-2000, 09:29 PM   #8 (permalink)
jbkrabs:
That is the same Unit I purchased. Hopefully the plug will come in tomorrow and I can get it hooked up this weekend. I will surely keep you informed of my demise or my success. Thanks for assisting in this project.
Old 02-18-2000, 12:35 AM   #9 (permalink)
Excursion7.3PSD, TRK4,
I decided to purchase the FORD AIC w/LCD. I have seen advertised units that are cheaper and more expensive than the FORD one. I do perfer the FORD version, just to try to keep consistant with reliability (good or bad). So far the documentation that I have read seems to tell me that the FORD version is able to store four programs. I only need one though.
Don't forget to post when you made your additions.
Regards.
jbkrab is offline
Old 02-18-2000, 07:59 PM   #10 (permalink)
jbkrab:
The install went great! Thanks for your info. It really is a neat gadget. I might be wrong, but your recovery from surgery, might not let you twist as much as these wires require. The space is confined and most of the time you are on your knees or back. If you have any one else mechanically inclined. Get them to splice and you supervise. E-mail me and I will give you my cell phone number and we will install it together. Good Luck with your surgery. You are going to enjoy that Excursion with all those toys and gadgets when you recover.
Old 02-18-2000, 08:07 PM   #11 (permalink)
Excursion7.3PSD,
Great to hear everything went well. Do you happen to have the part number for that connector? I would like to order it. If not, I already have my stuff ready with quick connectors on and tagged, ready to install. The best man from my wedding happens to own a Muffler shop. So on a Sunday we plan on hooking everything up in a nice warm shop with a lift.
Regards,
jbkrab is offline
Old 02-18-2000, 10:57 PM   #12 (permalink)
The biggest headache I had was with the connector. He got one off the spare shelf not in a wrapper so I could not tell you the part number. The one they sent was a 2 prong connector which was definately wrong. Sounds like you have the set up for install once it arrives.
Old 02-05-2001, 06:50 PM   #13 (permalink)
ptemplin,
No, the connector for the APCM is NOT installed on the Excursion. But all of the wireing is there. The two main wires you need to access are available just to your right knee at the OBDIII connector, both of the +/- Bus wires are located there. Plus you will need 12V and ground. All of this is written up in my other posts.
Regards,
Ben
2000 XLT EXCURSION, 4X4, Chestnut, PSD, 3.73 LS, AT Tires, Skid Plate, Tele PWR TT Mirrors, Chrome Wheels, Reverse Sen. Aid., K&N Air Filter, 3 Guages, TTM, APCM, W-D Turbo Brake, Towing a 2001 Dutchmen Supreme Travel Trailer Model 31BH4-DSL.
jbkrab is offline
Old 02-06-2001, 12:02 AM   #14 (permalink)
Does the PATS connector occupy the connector for the APCM? If so, can I simply disconnect the PATS and put the APCM in place of it, or do I need to manually splice in to get the APCM going?
Either way, where's the best place to go for 12V key-on power and ground near the PCM?
New Baby: 2001 Excursion Limited PSD 4x4 in Oxford White
3.73LS, Heated Seats, and those darn Firechicken tires. Added TTM, K&N air filter, AIC. Turbo Preluber on order 2/1.
ptemplin is offline
Old 02-06-2001, 11:11 PM   #15 (permalink)
What is the purpose for having an idle controller? Does it help the engine with performance and if so how? Forgive me for not knowing, but I will be buying my first PSD X next month and I am trying to become educated.
Gearguy is offline
