Old 06-27-2005, 08:44 PM   #1 (permalink)
Auxillary Fuel Tank For The X
I know some of you are going to think I"m crazy (like 44 gallons ain't enough), but is there a place to install an Auxillary tank? Anyone making one? I hate having to stop and refuel on long trips. When you're empty, you always end up at the most expensive gas stations. It also takes about 20 minutes off your trip.
Is the fuel tank plastic or metal? I was thinking you would probably have to weld into the present tank to harness some type of hose to connect the 2.
I thought someone might have already done some research on this subject (wanting to do the same thing), and I love gathering info before getting into such a major project [img]/ubbthreads/images/graemlins/wink.gif[/img].
dartit is offline
Old 06-27-2005, 10:30 PM   #2 (permalink)
clamgulch's Avatar
Re: Auxillary Fuel Tank For The X
Stock tank is plastic and sits in a steel cradle. I have never heard of anyone on this site wanting a bigger tank nor of anyone building one. Not sure where you could put it either once you consider the filler neck, there just isn't room.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
Old 06-27-2005, 10:45 PM   #3 (permalink)
I don't know where you are located, but if you are anywhere near Northern CA, a company called Transfer Flow in Chico CA makes them. I don't know anything about the tank, but the company is very reputable. I had tanks installed in an H1 and they were perfect.
BayAreaBoater is offline
Old 06-28-2005, 11:04 AM   #4 (permalink)
You aren't the only crazy one! I thought about this a while back, but never persued it. Too many other projects going on. Keep us posted, I sure hope it works out!
Earlier Post
...danny
2001 'X' 7.3l PSD 4x4 Limited
Oxford White / Medium Parchment
K&N Air filter, Husky Floor Liners
20' H&H Speedloader MX Tiltbed Trailer
Bilstein shocks(BE5-6208 front, BE56209 rear) $259.80 to my door.
AllAboutJeeps is offline
Old 06-28-2005, 12:33 PM   #5 (permalink)
I just called Transfer Flow and they don't make one for the X. This will probably be a custom build.
dartit is offline
Old 06-28-2005, 11:22 PM   #6 (permalink)
My Photos: (16)
If your habit is running until empty, then I think that you would probably do the same if you had more capacity.If your short a few gallons of getting to your destination then dumping in half a tank should only be 5 mins if you have removed the filler restricter. That way you can use the truckers pumps. I have thought about doing the same thing but I found this a lot easier.
DUNC [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Y2K X Ltd 4X4 PSD.Estate Green all options. DI 4 POS CHIP 50-75-100-140HP/K&N,Ram air,Regulated turbo vacume,Zoodad,Banks s/s 4" dwn pipe/exhaust,5" tip. Pre pump,tank mod, 203Thermostat and billet housing, Racor 460 filter-heater-water sensor,coolant filter,shift kit,exhaust brake, T/Q lock up,4X4 Front wheel lockout,High output alt with low rmp curve for max amps,Hellwig sway bar,4X2 Hatch Struts,Air horns,Viar 450 compressor,cab/Runningboard lights(Euro flash),Monroe Reflex,V Springs front,F springs modified rear,PowerSlot Cyro F/R, Hawk LTS F/R,Dueler Revo A/T 285/75/16,PSD badging, Isspro guages.C.B ,APCM, Locking Fuel Cap, Mud Guards, Door Edge, Bug Deflector, Window vents, Custom made Excursion leather jacket, General Coach Y2K 30' Citation T/T, Reese Dual-Cam Sway Bar, Reese Brakeman Digital control,Running light momentary switch.Back-up Camera.
DUNC is offline
Old 06-29-2005, 01:28 AM   #7 (permalink)
Sorry it wasn't much help. I know I saw the Excursion listed in one of their ads a while back. Maybe it was for another item that they sell???
Good luck with your project.
Old 06-29-2005, 03:51 PM   #8 (permalink)
What is and How do you remove the filler restricter?
2005 Excursion 6.0 4X4 EB 4" MBRP Turbo back 5" tip, Zoodad, Steveracer, Midland 79-290 CB, Wilson 5000, outlook monitor, DR 3" lift W/ Bilstien Shocks, U and Mod B codes, Billet Badges, 05 Powerstroke Badges, Weld Cheyennes 18x10, Mickey Thomspon 325/60-18's, DynaMated interior, Strobes, Train horns, 30mm rear and hellwig front sway bar, HIDs in Headlights, Fogs and backups, AIRAID Intake system, Randy Ellis light bar, 4 KC's, oilgaurd, FASS, LED markers, Bean's 190cc Injectors, Bean's Turbo, ARP Headstuds, Banks IC, Custom Fuel System, SCT by Kermit, More to come...
14.109 @ 95.96mph best 1/4 for now, Oh ya @ 8520lbs
AUGSX is offline
Old 06-29-2005, 05:03 PM   #9 (permalink)
My Photos: (28)
AUG
What kind of sylvania 9008s are you running. I didnt think anything was out yet...
'99.5PrairieTan/XLT/4x4/CC/SWB/7.3
<u>PARTS FROM DI:</u> 6 pos Chip, MM inj., Custom DIIC, AFE2, Fass 150/180, Garrett GTP38r, Full fuel system w/ Billet sump and reg. return, HX mod, Built tranny w/ PI TQ. Conv., 4 pod w/ Autometers, Centric slotted rotors/pads
Ceramic coated ported manifolds from BWD
6.0 cooler, 05 ext conv, 3.5 lift, 35s on 20s
truckpics
ptsuperd is offline
Old 06-29-2005, 05:22 PM   #10 (permalink)
They have a bulb out that is supposed to put out like 20% more light, NOT. The upgrade harness from Black Cloud Diesel made a huge difference.
Aug
AUGSX is offline
Old 06-30-2005, 09:39 AM   #11 (permalink)
My Photos: (28)
Is it the "white" light like the Silverstars put out?
truckpics
ptsuperd is offline
Old 06-30-2005, 12:52 PM   #12 (permalink)
My Photos: (16)
Take the cap off and look to see if there is a plate with a hole in it
for the nozzel. If so you can cut it out with a dremmel. Remove 3 bolts holding the filler pipe and unclamp from the rubber hose leading to the tank. Take it out and cut out the plate so its just one big hole. Wash and rinse for any debris. Reinstall and now the truckers nozzels will fit.
DUNC
DUNC is offline
Old 06-30-2005, 01:37 PM   #13 (permalink)
Nope it deffinatly ain't white light.
DUNC, thanks I'll go do that tonight, I just love all these free mods.
AUGSX is offline
Old 06-30-2005, 01:56 PM   #14 (permalink)
My Photos: (28)
Thanks AUG
truckpics
ptsuperd is offline
Old 07-01-2005, 06:03 PM   #15 (permalink)
Not crazy at all, I looked at installing a tank where the pickups hold one. That spot is open on the X. The problem is filling &amp; a stock F250 tank won't just go there. The stock F250 tank is too tall at the highest point. If it did fit, you would have to install a fill tube in the wheel well.
I'm glad were talking about it, because I'm interested in going WVO on both trucks and I don't want to lose the stock tanks and the fuel capacities for diesel fuel. The WVO would be a complete addition which would give the most flexability out on the road.
I've thought about getting some stainless steel and welding one up. That would last and have no bad side effects with WVO or Diesel.
If enough people want one, then the price to manufacture comes down.
My Photos----- BTS BUBBA "Life Member"
2002 7.3L Excursion 4x4, FTVB, MBRP 4" SS Exhaust, Rancho 9000X shocks, "V" code Front Springs & "B" Code Rear Springs, Ride Rite AirBags, Rear Hellwig Swaybar, Cut Front BumpStops, DieselSite Ext Trans Filter Kit - Coolant Filter Kit & 203 stat, "Scotpart" mod, "Hutched & Pooned", "LandYot" Radius Rods US Gear Overdrive 75mph @ 1750rpm's
2001 7.3L F350 CC LB 4x4 5" Exhaust, pillar guages, BTS Trans, US Gear Underdrive, DP 6 pos chip, V10 Trans Cooler, DieselSite - Coolant Filter Kit, Evans Coolant, 203 stat, DI reg Fuel Return, GT38R BB Turbo, AFE 2 Intake, Banks Intercooler, Air Rite Bags,
2000 Excursion Limited V10 4x4 7" Lift
"Family of 5 saved by Grace"
Snowman269 is offline
