Old 06-19-2008, 10:45 AM   #1 (permalink)
Send a message via AIM to gquodala
B Code Mods
Hi All:
Can someone help me with instruction on how to modify the B-code springs for my excursion? I just purchased new springs from Ford. They have 2 riveted metal bands around the leaves and i'm wondering if I have to remove the bands to add the two leaves from the old spring packs.
A link on how this is all done would be best but any help is appreciated.
Gino
02 Ford Excursion LTD - AFE Stage II, 4" MBRP Exhaust, Garrett Turbo, AIH Delete, Zoodad, CCV Mod, Warn Premium Hubs, Gulfcoast Bypass Oil Filter, Fumoto Drain Valve, DP-Tuner. 4 Autometer Gauges (Bosot, EGT, Coolant, Trans), Coolant filter, GOS Headlight Wiring upgrade, Ellis Light Bar, PIAA fog/driving lights, Yellow CAC pipes
gquodala is offline
Old 06-19-2008, 02:25 PM   #2 (permalink)
bpcheramie's Avatar
Just to watch the thread.
01 Excursion 4X4 - DIY Injectors, Garrett GT38R, DI Regulated Fuel Return, HX CrossOver, AFE stage II, Diamo 17 Karat 18x10.5 w/ 325x60x18, 4" straight pipe exhaust, DI 6 position chip, X and F Springs with F350 Rear Blocks and .....................
01 Excursion 4X4 - RIP 2/22/2008
All work has been done by Diesel Innovations!!!!! Thanks to MR POWERSRTOKE RACER for all the help.
bpcheramie is offline
Old 06-19-2008, 06:59 PM   #3 (permalink)
Take the two shortest leaves from each of the Excursion spring packs and add them to the B code spring packs between the shortest leaf and the overload leaf. The centering bolt from the Excursion spring pack should be long enough to hold the modified B code spring packs together. Discard the Excursion anti-wrap leaf and put it all back together using the Excursion spring block. Pretty easy swap and the ride is noticeably better.
Rear F code modification pics-instructions
2004 4X4 Excursion XLT 6.0L Black, intake elbow, straight pipe, modified W and B code springs
1945 Ford GPW
1973 Jeep CJ5 350, NP435/TeraLow geared Dana 20 and lockers
1988 Dodge Ramcharger 360, NP435/241, D60s, 37s
1963 Dodge M43 Ambulance
7.3L IDI project engine
yanvaryjt is offline
Old 06-19-2008, 08:29 PM   #4 (permalink)
Thanks all. I will take a look
gquodala is offline
Old 06-20-2008, 07:57 AM   #5 (permalink)
Also remove the sheetmetal spacers of the B codes and replace them with the 1/8" Aluminum spacers from the Ex springs.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 06-20-2008, 08:07 AM   #6 (permalink)
bpcheramie's Avatar
Ok am I the only one that comes up with you dont have permissions to view the how to on this? I just did an Fcode swap and think about pulling them back off and adding the leafs but want to see what needs to be done before I do it.
Brent
Old 06-20-2008, 09:02 AM   #7 (permalink)
Have the same problem with the link. It used to work before the BB change. Will continue to dig around for a good link.
Ty
1945 Ford GPW
Old 06-21-2008, 10:13 AM   #8 (permalink)
I came up with this mod and if you PM me I'll give ya my #..its a easy mod and I can tell you what you need to do.
Cary
2006 Yamaha FJR1300
caryt is offline
