Old 10-28-2007, 03:22 PM   #1 (permalink)
Best exhaust?
What's the best fitting, non-droning, exhaust/muffler combo out there?
Straight pipe is way too loud for me pulling, I'm not in high school anymore, lol. Looking for a 4" system w/nice mellow, throaty sound. Single outlet, swept back/down exit.
Right now my 1st choice is the Magnaflow satin stainless w/24" XL muffler and 5" rolled edge tip.
I see they make a 4" or a 3.5" dp, is the 4" dp too tight to be practical?
Suggestions??
Thanks for the advice.
2000 X, 4x4, White, Limited, PSD
Walker BTM
Isspro guages and DP F5 on the way....
SOLD **
99 Dodge 2500 CTD, 4x4, 5sp, QC, 275's, TST PowerMax Comp w/remote, Stanadyne LP & H20 Sep., Larry B heat shield, Wix BHAF, Outwears cover, Rip Rooks 4" exhaust, Magnaflow muffler & 5" tip, 3rd gen 17" chromies, KYB MonoMax's, power/heated tow mirror conversion, Alpine XM CD, Sirius Radio, Garmin C330 GPS, Prodigy brake control.
ckspeed is offline
Old 10-29-2007, 05:10 PM   #2 (permalink)
Re: Best exhaust?
I agree on the Magnaflow kit. It will give a nice low rumble without being too loud. Also, the 4" down-pipe will fit without issues. You might as well stick with the 3.5" though unless you plan on going all out. If you have any questions, give us a holler.
www.performancetruckproducts.com
Nate Dwyer- owner
4" Stainless exhaust $299 shipped
Best Prices
Best Service
Fastest Shipping
GUARANTEED
DSTRBD is offline
Old 10-30-2007, 06:13 PM   #3 (permalink)
Re: Best exhaust?
I run a 4" MBRP with 4" dp and the sound is nice.
2000 "X" Gauges, DP tunes, MBRP 4", AFE intake, ATS turbo, ITP overboost, Foil delete, New boots, BTS Trans, Trans cooler, H20 filter, Landyot Rods, Air bags with onboard air, bilistens, AV system with x-box, DVD, converter, ect....
Seven3Smoke is offline
Old 10-30-2007, 06:44 PM   #4 (permalink)
Re: Best exhaust?
Is there an advantage to the 4" dp, I've heard some say better low end w/3.5 but might just be talk.
Walker BTM
SOLD **
ckspeed is offline
Old 10-30-2007, 11:09 PM   #5 (permalink)
Re: Best exhaust?
The 4" works well with the ATS turbo housing and an AFE intake system.
Old 11-01-2007, 06:20 PM   #6 (permalink)
Re: Best exhaust?
I just put on a Diamond Eye 4" exhaust today. I'm putting off the downpipe upgrade until/if I get another turbo (most likely a Garrett BB next year).
SU
2001 PSD Excursion @ 150K
DR 4 1/2" lift w/modified v & b codes
Bilsteins on the corners
Hellwig Anti-Sway
Pro Comp 35" w/ APP Rims
Tymar Intake
4" Diamond Eye Exhaust
Edge Evo II Gauges with DP Tunes: Stock, Econo (80), Race (120)
Go Utes!
guyskoy is offline
Old 11-01-2007, 08:22 PM   #7 (permalink)
mike650's Avatar
Re: Best exhaust?
I've heard the same that a 3.5 DP is better for low end with a stock or slightly modified setup unless your going to do some HP modifications to take advantage of the 4" DP.
If you go 4" DP it should go in no problem.
We have the Banks monster exhaust and it sounds real nice.
Magnaflow is nice as well, I really like their rolled tip vs the Banks tip.
-Mike
2002 Excursion ~ Limited Ultimate ~ 7.3L PSD ~ 4x4
Mineral Gray, Limited Premier Group & Monochrome Package, two tone leather interior (pre-Eddie Bauer), TTT Mirrors, 3.73 Limited Slip, F250 Lariat wheels.
Kentucky Born: 4/9/2002
Improvements: 2002 PSD Badges, and lot's more!!
mike650 is offline
Old 11-01-2007, 11:58 PM   #8 (permalink)
Re: Best exhaust?
I spoke to Jody at DP today about an F5 chip, he also suggested sticking with the 3.5" pipe for the same reason, more low end torque w/stock injectors. So, I guess it's a win win win, cheaper, more torque, and easier to install.
Walker BTM
SOLD **
ckspeed is offline
Old 11-03-2007, 05:43 PM   #9 (permalink)
Re: Best exhaust?
Anyone have problems with drone with any of their exhaust setups? Supposedly......the X is very prone to this.
Walker BTM
SOLD **
ckspeed is offline
Old 11-07-2007, 01:18 PM   #10 (permalink)
Re: Best exhaust?
Even the stock exhaust system drones at highway speeds, get some dynamat and cover the floor.
2001 Excursion 7.3 Limited 2wd Grn/Tan 175k
2005 Infiniti G35 6MT Sedan Blk/Blk
mykidsarebrats is offline
Old 11-07-2007, 04:34 PM   #11 (permalink)
mike650's Avatar
Re: Best exhaust?
You can do a search on this site. There's been plenty documentation about this with a whole lot of opinions but like mykidsarebrats said, I don't think you'll be able to completely eliminate it. I guess I'm lucky and don't really notice it on mine.
-Mike
mike650 is offline
Old 11-07-2007, 06:43 PM   #12 (permalink)
Re: Best exhaust?
I have some with the magnaflow system when I am in any of the program modes. Stock not as much.
Beast is offline
Old 11-07-2007, 11:49 PM   #13 (permalink)
Re: Best exhaust?
Beast, your sig says MBRP, did you swap? If so, was it worse with the MBRP or Magnaflow?
I don't notice any drone on mine stock. Does the dynamat really help? Cover the whole floor, or just the back?
Walker BTM
SOLD **
ckspeed is offline
Old 11-08-2007, 07:26 AM   #14 (permalink)
Re: Best exhaust?
OOPS. Its MBRP. Good catch. I don't know what I was thinking. If you do change you may get the drone.
Beast is offline
Old 11-08-2007, 04:05 PM   #15 (permalink)
Re: Best exhaust?
I would stay with a 3.5 dp even if you go above a chip air cleaner or tow alot. I have the Hypermax 5" exaust with a 3.5 dp and I'm very happy with it,no drown and it is quieter than the 4" exaust that I had before and it fit great considering it was 5". I made 479 hp & 930 ft lbs and ran 13.75 @ 97 mph all with a 3.5 dp.
Roger
Y2K EXCAR lmd 4x4 psd:
H2E W/Comp. Mod, Tapercore, Afe stg. II, Mini Me's, John Woods Trans, DI fuel system and Jody's tunes.
rogerr is offline
