best fuel de-icer, and anti gel? - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 12-27-2004, 08:58 PM Thread Starter
turbodave's Avatar
It never fails, once or twice a winter, my fuel lines or something gels up and leaves me stranded and waiting for a tow to the local Ford dealer. I'm getting real tired of it.
What are your recommendations for the best brand de-icer, and anti gel additives?/
BTW, I've tried Howe's and it was a miserable failer.
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, 177K, TTS chip (original owner)
86 Buick Grand National (original owner)
87 Buick Grand National (second owner) (Sold)
12 Lincoln MKT, 3.5 twin turbo Ecoboost
turbodave is offline
post #2 of 15 (permalink) Old 12-27-2004, 11:40 PM
CHPMustang's Avatar
Re: best fuel de-icer, and anti gel?
I've read that Arctic Express and Diesel 9-1-1 works well.
Are you using any additives such as Diesel Fuel Supplement + Cetane Boost each time you fill up during the winter?
Bill
2002 Ford Excursion 7.3L 4x4 XLT
, 6.0L cooler,
Magnaflow 4"- FRX CVD Valving - FRX Crossover - HPX
Bilstein 5100's - AFE Stage 2 - Adrenaline HPOP
LandYot's
CHPMustang is offline
post #3 of 15 (permalink) Old 12-28-2004, 03:56 AM
crumm's Avatar
My Photos: (38)
I've tried Howes and it was a miserable failer.
You must have not used it properly. Howes will pay your tow bill if you gel while using there treatment. Howes Lubricator is the #1 selling brand of Diesel Additives in North America. I have had good luck with Howes and Schaeffer's.
1996 F-350, 4X4, XLT, C/C, 5sp, 4.10, Chip, DPPI Down Pipe, Tymar intake, Shackle reversal, 315 Toyo MT's, 67,000 miles.
crumm is offline
post #4 of 15 (permalink) Old 12-28-2004, 06:38 AM Thread Starter
turbodave's Avatar
Bill
Yes, I do, with every fill up. I cant remember the brand, but it's everywhere, especially at the truck stop I get my fuel.
It comes in a grey bottle for summer use (cetane booster), and a white bottle for winter (supplement+cetane boost+anti gell). Maybe I wasn't using enough. Used a half bottle per tank.
H&N Turbo 6 Racing
Seviervile TN
post #5 of 15 (permalink) Old 12-28-2004, 06:40 AM Thread Starter
turbodave's Avatar
I've tried using it per the label directions. I've even tried it a little stronger.
I'm not worried about the tow cost, I've got AAA. I just had the pain in the butt of having to be towed.
H&N Turbo 6 Racing
Seviervile TN
post #6 of 15 (permalink) Old 12-28-2004, 09:15 AM
CHPMustang's Avatar
Sure sounds like Power Service as I use the grey summer and white winter on fill-ups.
We were in the 0-18 degree range for days and didn't gel up,I add 5 ounces additive to every 15 gallons fuel both seasons.
post #7 of 15 (permalink) Old 12-28-2004, 10:15 AM
Dave
I Don't see why you are having problems I am not far away in Asheville and have filled up in TN many times when cost was lower than here and that is most of the time.
I have used the power service since my truck was new I did use the Rotilla product when Sam's had it but I have not seen it around.
I only use about 2 cups per 36 to 40 fill up so I am not using as much as they say but I try to use only fuel that should be blended. I buy it in the large bottle and refill one of the white small bottles that fit next to the jack in the back, that way if it leaks it is on that rubber and since it is by the blower you know about it right away.
I figure using the stuf is about free since my MPG goes up about .5 anyway.
Knock on wood but I am close to 100k without haveing a gelling problem.
We were in michigan over the holliday and it was 2 degrees Christmas morning, plugged it in for two hours and it made a little racket for less than a minute then the warmer oil and water warmed the rest of the engine and it was normal.
Are you filling up out on I 40 or a local place that still may have #2? If you think you may be getting number 2 then follow the recomended "dose" then add a little and you should be fine heck it does not get that cold here.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!
(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
Bruce1954 is offline
post #8 of 15 (permalink) Old 12-28-2004, 10:24 AM Thread Starter
turbodave's Avatar
Dave
Bruce
Sorry Bruce, my "location" info is supposed to say Sevierville TN (SOON). I'm not there yet. House should be completed in a couple weeks.
Right now, I'm still up here in MI, the temps over the last 4-5 days have been in the low single digits everynight, and nothing over 15 days. [img]/ubbthreads/images/graemlins/frown.gif[/img]
H&N Turbo 6 Racing
Seviervile TN
post #9 of 15 (permalink) Old 12-29-2004, 01:32 AM
...I've tried Howe's and it was a miserable failer.
Hmm, that's interesting. I've used Howes for many years in many different trucks and NEVER had a problem. In smaller trucks, like our Excursions and pickups, Howes says to use twice as much treatment as directed for large trucks. I use a full bottle of Howes per tank in my Excursion. That's a bit more than required but it doesn't hurt anything and it's easy to measure. Over-treating diesel fuel with Howes has no detrimental effects.
Based upon my experience with Howes, I don't see how anyone could have a problem with it if they followed the directions.
I live in Wyoming and I treat ALL the fuel going into any of my trucks during cold weather. Gelled fuel sucks at best and can get you killed at worst, so I don't take any chances.
00 Excursion Limited, Detroit Locker, (rear), X code front springs & f-350 rear blocks, Edlebrock Shocks, Firestone Air Bags, (rear), Helweg Anti-Sway Bars, (front & rear), Rancho Steering Stabilizer, BFG A/T 285's.
OB-1 is offline
post #10 of 15 (permalink) Old 12-29-2004, 06:54 AM Thread Starter
turbodave's Avatar
When you say a bottle per tank, what size bottle are you talking about? I decided to give it another try, and bought a bottle yesturday, but it's a pretty large bottle.
thanks.
H&N Turbo 6 Racing
Seviervile TN
post #11 of 15 (permalink) Old 12-29-2004, 02:27 PM
thanks.
I use the large bottles which treat 250 gallons in a large truck or 125 in a small one. Since you're in TN, I'd use a full large bottle for 2-3 tanks and then use 1/2 a bottle per tank after that.
Truckstops usually charge about $10/bottle for Howes. A local Farm & Ranch store gets $7.50/bottle. I went on-line and found a local distributor and now pay about $6.75/bottle. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
OB-1 is offline
post #12 of 15 (permalink) Old 12-29-2004, 05:05 PM Thread Starter
turbodave's Avatar
thanks.
Wow, a whole bottle for an excursion tank??
BTW, I'm still in MI!!! [img]/ubbthreads/images/graemlins/frown.gif[/img]
H&N Turbo 6 Racing
Seviervile TN
post #13 of 15 (permalink) Old 01-19-2005, 07:01 AM
I have been using Standayne Performance Formula since I bought the Excursion. The label recommends 16 oz. to treat 60 gal. of diesel.
In conjunction with 5W30 Amsoil synthetic diesel oil, I have started in temperatures as cold as -27F, I use #2 diesel whenever I can get it.
I replaced the batteries when they were 4 years old.
My diesel has never been kept in a heated garage, IT HAS NEVER BEEN PLUGGED IN!
IT HAS ALWAYS STARTED!
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, Edge Evolution II, WalkerBigTruck Muffler, RS9000, RS5410, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Air Lift rear air bag system, Amsoil from
in engine/diffs/trans/transfer 430k miles.
ExcursionPSD is offline
post #14 of 15 (permalink) Old 01-19-2005, 11:03 AM
Schaeffer's #300 Arctic Flow Plus. I have used this to treat both highway and off-road (un-cut) fuel. Following the usage guide (approximately) I have not cut my off road fuel with kerosene for two winters now. Great stuff!
SMTatham is offline
post #15 of 15 (permalink) Old 01-20-2005, 11:42 PM
live here in mi to don't plug in and never had any gelling yet
loud and rough on them cold mornings but always starts 03 6.0
just started pluging it in thought to shorten the warm up time.
bought some powerservice (white bottle) today for the milage increase
leave on a ski trip tomorrow will see if it works.
4play is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
