My Firestones look awful puny in my wheelwell. Anyone have information comparing the BF Goodrich 295s to the Firestones. How does the ride compare assuming no other modifications? I want to spring for the bigger tires because I'd like to fill out the wheelwell more, but I don't want to sacrifice ride. Any advice?
'00 Excursion Limited PSD 4x4, Toreador Red, Parchment interior, 3.73 limited slip, heated seats, 6 CD changer, VCP, dual screen flip-down LCD T.V.s in overhead console, bug deflector, rear air deflector, window air/rain deflectors, heated and telscoping mirrors, Lexan front grille cold shield, PSD badging on order
'00 Exc Ltd PSD 4x4, Toreador Red, 3.73 LS, heated seats, 6 CD changer, VCP, 2 o'head T.V.s, bug-rear air & window air/rain deflectors, heated and tele mirrors, Lexan grille cold shield, PSD badges, Husky liners front, rear and cargo section, Dunlop Rover AT LT285/75R16s, 8 rear door subwoofers, amp in jack stowage area.
I put 295 BFG TA KO's on my 350 CC today and then drove about 150 miles. I have not made any other suspension changes yet. The ride is definitely improved. Road vibration is less and the vehicle handles better on the very bad roads. There may be a very slight increase in road noise; detectable in the X but not in the CC. We have not found any change in fuel economy on the X (the PCM was recalibrated). I am guessing that the lower effective gear ratio is evenly offset by the increased rolling resistance of the wider tire.
I think the change is worth the investment just for the actual performance gain. Since I have lost confidence in Firestone and will not have them on any vehicle I own, the change has become mandatory.
BTW: If you have moulded mud flaps, you will get a slight amount of rubbing of the tire on the flap when the wheels are turned fully. On both my vehicles, the rubbing is on one side only. I expect after 10,000 miles or so it will stop as the tire starts to wear down.
I just noticed today that the X rubs on both sides.
2000 Excursion LTD 4x4, Oxford White, PSD 3.73, K&N, Hypertech PPIII, Dynomax Muffler, Ramsey Winch Mount & Grill/Brush Guard, Edelbrock Shocks, Rancho Stabilizer, PIAA 90 PRO XT Lights, 295/75R/16 BFG TA KO Tires, 2000 F350 CC PSD Woodland Green, 3.73
[This message has been edited by POLR BR (edited 09-18-2000).]
