WHAT IS THE LARGEST TIRES ANYONE HAS GOT ON AN EXCURSION WITHOUT ANY MODIFICATIONS (BODY OR SUSPENSION) AND STILL BEEN DRIVABLE?
IF I DO A LIFT, IS PROCOMP STILL THE ONLY ONES DOING KITS FOR EXCURSION?
THANKS FOR ANY REPLIES.
2005 "AMARILLO" PACKAGE F250 CREWCAB, LONG BOX, POWER MOON ROOF, LEATHER INTERIOR, HEATED POWER SEATS, TOW COMAND, UPFITTER SWITCHES, TEMP/COMPUS/HOMELINK MIRROR, POWER REAR WINDOW, ARE BED COVER W/SPOILER, 6 DISC IN DASH, SHIFT ON FLY, BODY COLOR GRILL INSERT, MIRRORS, LOWER VALANCE, LICENSE PLATE BRACKET, COWEL COVER, MUD GUARDS, SIDE STEP BRACKET COVERS, REAR BUMPER/HITCH PLATE COVERS, AND IS THAT YELLOW EVER "SCREAMING", AS FORD PUTS IT!!
In the BFG line, the 295 BFG TA KO's are about it. 305 Goodyears are about the same diameter and will probably fit like the BFG's. The 295's rub the moulded mud guard slightly at full wheel extension. Wife's X rubs on both mud flaps, the 350 on one side only. I guess I must be out of square. Regular flaps probably won't rub or you can take the moulded ones off for 10k miles and put them back on after the tire wears down a bit. I have left my moulded flaps on as the noise is not that bad. I defintely would not go any bigger without doing some type of lift. Somebody on this board installed the 450/550 springs on the front. If you get a 1 1/2" front lift from these springs as reported, you might be able to go several tire sizes more.
If you go with 295's make sure to recalibrate your PCM. On my X the larger tires made a difference for the worse on how the tranny shifted. For some reason the 350 is not as noticeable but I am still going to have the PCM reacalibrated anyway. I like the idea of the speedometer being accurate. You don't want to give Troutly and gang more opportunities than they deserve.
JDALLEN, skyjacker, fabtech, superlift all make lifts for the xcar I have 35*12.5*16.5 on mine with a 4" lift and no problems. mike
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
I have BFG 295 KO's. Like POLR BR, mine rubbed slightly on the moulded flap but only on the drivers side and only when fully turned. After a few thousand mile I quit hearing/noticing. The front end replacement I installed lowered the front slightly. I just installed the 450/550 springs which lifted the front 2 inches and now it rides level. 40.25 inches from ground to top of wheel well. No telling what size tire I could use now but I will probably stick with the 295 KO's. They have been great tires so far with 25K.
00 4X4 PSD Excursion Arizona Beige XLT Loaded: Leather, 3.73 LS, BFG 295 KO's, PSD Badging, Westin Nerf Bars, Fumoto drain valve, K&N Air Filter, Hypertech PP III, Ranch Hand FER, 450/550 front springs, Pro Comp Steering Stabilizer, Edelbrock Shocks soon
00 Excursion XLT 4X4 PSD Arizona Beige 3.73 LS BFG 295 KO's Westin Nerf Bars Fumoto valve K&N Air PP III Ranch Hand FER & Bumper X Springs Pro Comp Stabilizer IAS Shocks Dynomax Brite Box Dual By Pass and Amsoil Front to Back Thule Racks Photos
POLR BR how is your trans shifting after calibration ? With the 265's I am running 1,500rpm at 50mph. What RPM does your PSD turn at 50mph with the 295's ?
The transmission shifted hard until the recal. Returned to normal afterwards. When I get my hands on the X, I will check the rpms against what you have posted. May be awhile however.
