Old 10-18-2004, 12:17 AM   #1 (permalink)
wow
Which Bilsteins should I buy for the 'X"
Remember that I'm not a 'Ford Guy', I'm a new Excursion guy trying to figure things out. I need to stop the rocking chair motion. The front end is stock now, but might be getting v-code springs, The rear will likely remain stock unless the 'smart people' on this list thnk that's a bad idea?
No lift kits coming. Truck has 305/70R16 Nitto Grapplers on stock Limited Rims, if that matters. 98% used on-road. Off road use most likely in mud and snow - often at the same time :-).
So, which Bilsteins should I buy? And who has the best price?
Wayne
2004 X Limited. Medium Gray Metallic, 4x4, 6.0L Diesel, DVD, LimitedSlip Differential, HD Tow Group, Transfer Case Skid Plate, Radius Rods, Remote Starter, Magnum Hitch, Nitto Terra-Graplers, Running Boards Removed, Large Payments.
wow is offline
Old 10-18-2004, 09:24 AM   #2 (permalink)
Re: Which Bilsteins should I buy for the 'X"
See the model numbers below in my sig for the Bilsteins . I think I got mine from Offroad warehouse .com .
jward is offline
Old 10-18-2004, 01:23 PM   #3 (permalink)
im running the 5100's it was included with my lift. i got a 5'' Donahoe Racing Edge kit. the kit also came with Deaver springs.
Sukhi
2000 Ford Excursion 4x4 7.3l Powerstroke Diesel.
8" Edge suspension lift. Donahoe Racing Res. shocks. Deaver Leaf springs. Fabteck 3.5" hangers. Mickey Thompson 38x15.50r20 MTZ's. 20x10 Jesse James Lawless 8 rims, AFE Stage 2 intake. Auto-meter guages: pyro, trans, boost. ART slotted rotors, performance friction pads. 4" turbo back SS straght pipe exhaust(no muffler), DP-Tuner 4 pos flip chip 80/100/120/140, Billet grill, Apc Projector head lamps. Clear corners, AMP Research power steps.
my other trucks
1997 GMC Suburban 4x4 6.5l Turbo Diesel.
1996 Dodge Ram 2x4 5.9l Cummins Diesel.
1997 Chevrolet Tahoe 4x4 6.5l Turbo Diesel.
1990 Ford Club Wagon Van 2x4 7.3l Diesel
1989 Chevrolet 1ton Van 6.2l Diesel.
2003 Chevrolet C4500 6.6l Duramax Diesel/Alison
powerstrokex is offline
Old 10-18-2004, 05:42 PM   #4 (permalink)
THe 5100's are an awesome stock replacement shock. I love them on my CC 4x4. But my EX has FOX so I cant tell you how they feel on an EX.
MY TRUCKS
1996 PSD F-350 crew cab 4x4, AB CODE CALIFORNIA TRUCK, 5 speed,CON-O SMFW modified by Southbend Clutch, ORU Reverse Shackle kit, 4:10, u.s. gear chip, IDM MOD BY ME , down pipe, 4 inch straight pipe, boost and EGT gauges,PRO COMP A/T's 305-70's, Bilstein's, ditched the k&n filter for an open element Baldwin PA 2818, kenwood & polk audio sound system.
2002 Excursion PSD 4x4 XLT Premium- TN BB 1.0 Turbo , 6.0 IC, 8 inch Sky Jacker lift, FOX shocks with remotes, 35-12.50R17 BFG Muds mounted on 17x10 Boyd Coddington Billet wheels, ORU Frozen rotors, custom hybrid intake, DVD/2 monitors, Billet grill, XM radio, DP Tuner PCM QLJ5/PMT1 combo, Edge Juice/Attitude for gauges.
SOUTHERN CALIFORNIA POWERSTROKES MEMBER
mattymx is offline
Old 10-19-2004, 07:20 PM   #5 (permalink)
For "non-lifted" Excursions, any Bilsteins other than BE5-6208 front, BE5-6209 rear are a HUGE mistake. Can't comment on shocks for lifted trucks. (The above work superbly. They have very little bump damping and lots of rebound. The other versions have too much bump damping.)
Cheers,
DC
DOC4444 is offline
Old 10-19-2004, 07:32 PM   #6 (permalink)
My Photos: (23)
DOC4444, do you know if those will also work well with Excursions that have V-Code fronts, and 4 inch block rears?
SeppDietrich is offline
Old 10-19-2004, 08:21 PM   #7 (permalink)
Perhaps Bruce should comment, but I think you would only lose about 1" of droop front and rear with that setup, so you should be fine. The shocks would probably also have good damping for even higher lifts. You would just need some sort of mount or eyelet extension to make up for the loss of droop. Alternatively, you could see if Bilstein offers the same valving in a longer shock.
DC
DOC4444 is offline
Old 11-17-2004, 01:22 AM   #8 (permalink)
Hey jward how hard was the hellwig install and do I have drill any holes? Thanks
X-PLAN
2003 6.0 Excursion Ltd. 4 X 4 Mineral Grey
build date 1/1/03 engine date 1/28/03 (Ind. plant)
delivery date 2/23/03
NO FLASH
current mileage 45,000
cal lic. PSTROKX
2001 Escape (wife's ride)
1997 F-350 Crew Cab 4 X 4 7.5
1994 F-250 Super Cab 4 X 4 7.5
RAD1 is offline
Old 11-17-2004, 08:48 AM   #9 (permalink)
Hellwig install was fairly straight forward although the supplied hdwr. was cheap quality. I ended up cutting off 1 hole of my vertical links so that the bar would sit as close as possible to level with the frame. Most here did not do that so probably works fine without the cutting. No drilling required for the rest of the install.
jward is offline
Old 11-17-2004, 08:33 PM   #10 (permalink)
My Photos: (13)
I've installed the Bilsteins and the rear Hellwig Sway Bar in my 2003 X. See my pics for how I installed them.
2003 Eddie Bauer Excursion (born 8 Apr 03), 6.0L Power Stroke Turbo Diesel w/8 C95 Fuel Injectors, Oxford White & Arizona Beige, 4x4, 5-spd Torqshift Transmission, 3.73 Rear, Two-tone Tan Leather Interior, Heated Seats, 6CD, Bull Rings, Adjustable pedals, Hellwig Sway Bar, Rancho 9000 Shocks, PSD Badges, Tekonsha Prodigy Brake Controller. McKenzie Starwood 29ft travel trailer.
[b]
My Excursion Pics (Updated 30 Dec 03)
<font color="red">CWO3, USN (ret), 24 years</font>
<font color="00FF00"></font>
MelloMike is offline
