Black Smoke & Hot Exhaust when towing - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 04-06-2007, 11:45 PM Thread Starter
I have a Stock 2003 Ford Excursion 4x4 with 6.0 Diesel. I pull a 12,000lbs trailer sometimes. When pulling up hill my trucks exhaust is getting very hot & blowing Black Smoke. Looking for help to keep cool & no black smoke.
expiditionbill is offline
post #2 of 6 (permalink) Old 04-07-2007, 01:47 AM
FamilyRide's Avatar
Re: Black Smoke & Hot Exhaust when towing
You've got a diesel. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] It burns diesel fuel. When you need more power, it adds more fuel, more fuel, more heat, more smoke. And when you're overloaded to 12k, it needs a lot more power, fuel, heat, smoke.........etc. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Welcome to the world of oil burners.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #3 of 6 (permalink) Old 04-07-2007, 11:05 AM
I recommend you do two things. Install a exhuast temp gauge and a transmission temp gauge. Keep the exhaust temp below 1250 deg. (pre-turbo) and keep the transmission temp under 225 deg.
The black smoke is just telling you your engine is working, which is a good thing. A diesel likes to work.
Best Regards,
2K Excursion Ltd Burg Auto, 193k
2K F350 DRW Lariat 6spd CC White/tan, 248k
Late 98 (04/98), WHT F250 Std Cab 6 spd, 365k miles
Coolant Filter, fuel and hpop crossover, Hutch tank mod,
open ccv, 6637 air filter
looks like a muffler (looks can be deceiving)
DP stock, 80T, 80E, 140 Extreme (normally in extreme and still get 19 plus mpg)
fuel gauge on bowl and shimmed return
Penny glow plugs at AutoZone
moxyspirit is offline
post #4 of 6 (permalink) Old 04-07-2007, 02:10 PM Thread Starter
Thanks for the tips.
post #5 of 6 (permalink) Old 04-07-2007, 10:23 PM
darsey715's Avatar
I could only get my truck to smoke when I had the edge installed and it was on level 5. I try and try and try...nothing. lol
2003 6.0 f250
darsey715 is offline
post #6 of 6 (permalink) Old 04-07-2007, 11:02 PM
Then it wasn't working! [img]/ubbthreads/images/graemlins/phoney.gif[/img] Maybe it's broke. Most times I just need to tighten the lug nuts. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
