Anyone out there removed it form thier X? How is it attached? How did you get it off? Did you put it back on? If so how? Looking to remove mine and paint it but dont want to have big problems when I remove it or reinstall it. so please any info you have would help. by the way any paint this stuff and what did you use? How about the grille also?
Brent
01 Excursion 4X4 - DIY Injectors, Garrett GT38R, DI Regulated Fuel Return, HX CrossOver, AFE stage II, Diamo 17 Karat 18x10.5 w/ 325x60x18, 4" straight pipe exhaust, DI 6 position chip, X and F Springs with F350 Rear Blocks and .....................
01 Excursion 4X4 - RIP 2/22/2008
All work has been done by Diesel Innovations!!!!! Thanks to MR POWERSRTOKE RACER for all the help.
The cladding underneath the filling cap keeps coming loose...
The diesel drips down at times and loosens the two faced tape that holds it on....
The 'nearest' thing I can think of to use would be some 3M 'exterior' two face tape...
The crap is expensive....like $4.00 for a 5 foot roll....You can get it most everywhere....Including office supply houses, WalMart, etc, etc...
The next time, I re-attach it, I'm also going to use some silcone adhesive, just to fortify it , from the diesel...
I took mine off one side a week ago to paint it. I used high test fishing line to cut thru the tape. The ones on the doors are just taped to the doors and the front fender and rear panel are screwed and taped. After spending alot of time and soar hands trying to scrape the tape off the paint I put the left side back on with 3m tape. My tape has the red cover on it and it will never come off. Now Im going to have mine repainted on the truck. Have you had any estimates of how much it cost to paint the plastic?
01 excursion, 4x4 3" lift 18" wheels, MBRP turbo back ,airraid intake,edge evolution, vegistroke system w/custom tank
I have talked to a few shops here and they told me like 500 and that is with me bring it in. I feel that is way too much so I am going to pull the off and get a gun to do it myself. Hope I do I good job. From what I am finding out it is only like 80 to 90 for me to get the stuff I need. Will post what I bought and pics once I am done.
Brent
I took mine off and left it off. The heat gun really helps get the residual tape off, but plan on spending an afternoon at it and wear gloves or you'll get blisters peeling that tape off.
Use adhesive remover. Body shop paint houses sell it. Also 3M makes an adhesive remover, and as was mentioned, a heat gun helps too. If you're going to cover it all back up, it doesn't have to look pretty underneath when you're done.... I'd use 3m adhesiver remover and scotchbrite pads.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
Do you still have the laying around? I would like to have a few of them to try a few diffent things on. If so send me a PM and lets talk about them.
Brent
Mine was peeling were the fuel spilled down. I paid a local shop $150 to remove clean and reapply. Once done, I used a bead of clear silcone to prevent the fuel from getting under the molding. So far so good.
John
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
