brakes on 2002 ex - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 07-17-2007, 10:46 PM   #1 (permalink)
brakes on 2002 ex
i had a 2000 x with a front rotor problem , to be exact 10 sets of rotors and calipers in 120000 , just wondering if the 2002 x has the problem fixed with bigger rotors do they still eat them up .
2002 excursion 4x4 v code frt's and custom b code rears . afe stageII filter assy. magnaflow 4" turbo back ,annihilator overboost , hpx line , dipricol optix pyro boost trans .dp tuner 80econo 120race .ats ported 1.0 housing .
777mechanic is offline
Old 07-18-2007, 12:55 AM   #2 (permalink)
Re: brakes on 2002 ex
What are your driving habits? Tow alot? Those are huge factors.
I'm a mod friendly Ford Diesel Technician located in Sacramento California area.
Gofaster23 is offline
Old 07-18-2007, 05:02 PM   #3 (permalink)
wifes truck zero towing 60% in town driving not a real hot rodder
Old 07-19-2007, 12:01 AM   #4 (permalink)
Couple of things
First with that many sets something is going on
I would look at the following.
You live in the mountains and or hills, so do I see Sig for both Xs
Have been checking the lug nut torque? I think not, it't critcal
Is wife riding the brake?
Ccheck caliper pins and pistons for sticking, I am dealing with this now.
Now after you check all the above and more that others will list the bottom line is you live in the mountains and from my experience std X brakes will not hold up.
I used ART rotors on my 02 after much going around and trying others.
I went back to them for the rotors for the 05 I put them on at 25 or 30k it started having problems at about 22k.
I have about 66k on it now.
Now I have the Performance friction pads from ART they work great but only when warm or hot. I will ask them for an alternative it they ever wear out.
I had the front left caliper off this past weekend to look at the caliper pins and found a likely sticking piston. The pads look new
Hope this helps
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 07-19-2007, 07:55 PM   #5 (permalink)
Just noticed I did not answer your question:
As far as I know all X brakes are the same size only change was some early 2000 Xs had staggered rear calapers.
I am assuming way more front than rear problems but do let us know.
Bruce
