Brakes/hubs/bearings need advice - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 11-03-2009, 09:50 PM   #1 (permalink)
PirateChaser's Avatar
I am about to pull apart the front brakes on the wifes 03 X. It pulls to the left some when braking. Since it is pulling, having read alot of the posts, going to clean the pins, etc. Since i am into it, is there any service that can be done to the hubs or bearings? I am not familiar with the Ford front end and don't know if they are all sealed bearings or what? Got to take a day off work to do this and want to do everything i can while i am in there. The only thing it is doing right now that isn't right is pulling to the left when braking.
THanks!!
2003 Excursion Limited 4x4 7.3L auto
2001 Dodge 2500 4x4 quad cab cummins, Fass Fuel system, straight piped
PirateChaser is offline
Old 11-04-2009, 07:42 AM   #2 (permalink)
njneer1's Avatar
The wheel bearing and hub are a sealed bearing assembly, not much you can do with them in the way of service.
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, Isspro EGT/Boost/ Trans temp.
1997 4runner,5spd,TRD supercharged,Bilsteins,H&R coil springs front and rear
1968 roadrunner,383,4spd
1970 roadrunner,383,4spd,pistol grip,58k 0riginal miles
1970 Charger,383,4spd,pistol grip,my first car
njneer1 is offline
Old 11-04-2009, 09:51 AM   #3 (permalink)
Guzzler has probably more documentation on this subject than anyone. I just replaced all my bearing/Hubs when they wore out
Welcome to guzzle's Ford PSD Web Pages
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
