Broken headlight switch - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 18 (permalink) Old 05-21-2011, 07:50 AM
OK... I have the 04 F-250 Superduty... same knob?
TJPatrick is offline
post #17 of 18 (permalink) Old 06-06-2011, 09:07 PM
detroitfd's Avatar
I did the same as clam, probably 2 years ago, and no problems since.
Jerry
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, Decel, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ S&B conical filter - Zoodad mod - Suncoast Extreme Duty Trans rebuild w/ TransGo Shift kit, Amsoil synthetic ATF & Magnefine inline filer - BD Triple Disc Billet Torque Converter - 4" Stainless Steel Turbo Back (4" down pipe) Magnaflow exhaust - ATS Turbo housing and 4" intake sleeve - Turbo Master Wastegate Controller - HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter w/ CAT ELC coolant - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge cluster face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub - 4.5" LED marker/turn lights in front bumper - ViAir HD onboard air system w/ 380C compressor, 2.5 gal tank & Grover stutter tone air horn - FireStone RideRite suspension air bags -
TOWING:
2004 Dutchmen 31BH travel trailer
detroitfd is offline
post #18 of 18 (permalink) Old 06-11-2011, 02:40 PM
Originally Posted by IMartin View Post
Just talked to the dealer. There are two knobs that will fit. The original replacement is p/n 1L2Z11661AA - $14.85. There is another one that fits but is configured just slightly different ("knob handle does not slope down like the original replacement"), p/n 1F1Z11666AA for $4.22. Hope this helps.
I just replaced my switch knob, and yes, the parts guy told me I had to buy the whole new switch..... I gave him the numbers from your post and of course he said,"Huh... well I guess you can get just the knob". Well, both of those numbers had been superseded by a singular number (which I don't have handy, but will dig up if someone needs me to post it) and that is the non - sloped knob, and apparently the sloped one is no longer available. The singular replacement is, you guessed it, $14.85... I guess they saw folks were buying the cheaper of the two, and adjusted according to their needs.
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
