So what year was it that they changed the bump stops to the solid (and slightly smaller) ones? My factory stops are toast (one is almost completely gone and the other is badly torn). I want to replace with the solid jobbies and get a little more travel. Springs are stock. Thanks in advance.
Proud American
01 4WD PSD Ex - EBM2 - Autometer's on the A, Mag-Hytec Tran Pan, Front Hitch, Dome Light Override, TTM, CCV Re-route, Coolant Filter, Hellwig Bar, Walker BTM, BTS Trans, DP-Tuner, BIG SMILE!
02 came with soft cone style. much softer upon impact. some use the superduty stop which are much smaller and should rarely hit them but they are solid.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: TXANGLER</div><div class="ubbcode-body">02 came with soft cone style. much softer upon impact. some use the superduty stop which are much smaller and should rarely hit them but they are solid.
Tx </div></div>
Early and Mid 02 had the older accordian style.
If you have an 02 with the new style we thought it was May or latter build or they have been changed.
As far as ordering order 03 stops and you will be good to go.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
Get a lift they come with bump stop and give you more travel. But anyways 4 wheel parts has brackets and new bump stops. http://www.4wheelparts.com/SCT1T101.aspx
2000 F-250, 6 SPD, 4x4, single cab long bed, 6" superlift, 36" Irok swampers, 7" Mitre cut stacks, ts 4 position chip, Tymar, HPX line, Boost and Pyro autometer gages, CCV w/ canister,warn hub locks
LED on bumper.. under cab.. top of cab.. on the back of bed. blah blah blah
Thanks guys - this was the info I was after. A lift is not possible, as the wife insists that both vehicle go in the garage at night - and stock I only have a couple of inches clearance. I was more interested in when they started putting the solid stops on - so that's what I'll order. Thanks again!
Proud American
Us or Vs are actually on my wish list - but the truck toys have to take a break for a while. The wife still gives me a hard time about my "Gold Plated" BTS Trans. She loves it though! For now I have to stick with regular maintenance items - which can be pricey enough with two teenagers in the house. The daughter decided that last week was a bad week - she clipped the garage with the Mustang, and the next day clipped another student's parked car with the truck. Aargh!
Proud American
