The left front caliper bracket pins (not sure what you call them!) are frozen. I have tried oiling and a wrench and hammer to try to "coax" them loose with no luck. Any ideas? I really need to get it back together today! That explains why the truck pulled when braking now I just need to get them loose.
Thanks in advance for your help!
Pas
Oh, it's on my Excursion with 115K on the clock.
2000 Crew Cab Powerstroke F250. Black Beauty
Did you slide the rubber boot back, stick the wd-40 nozzle stick in and then try to push the boot back around it?
I don't remember what size wrench this was 17MM possibly.
Do you have access to an impact?
A tight fitting box end and a hammer works well, can you tap on a SAE box end and give it a whack?
Keep at it it will come
Note they are different one has a flat and one is triangular as I recall but don't remember how they go.
You could just remove the whole calaper assy and exchange for rebuilts.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
I'd suggest vice grips, heat, penetrating oil, and lots of arm strength!
When I replaced my caliper pins, I guess I got lucky. Three of the four pins pulled right out, easy as pie, but the fourth was lodged in there pretty tight. It took a minute or so, but I was able to remove it without using pliers or penetrating oil.
After I removed the pins, I wrapped a drill bit with some nylon scrubbing pad and used my cordless drill to carefully clean out the bore. A few shots of brake cleaner and the bore was as shiny as a new nickel!
I coated the pin and bore with some Ford Motorsport caliper pin lube and viola, good as new.
Stewart
1999 F150 Lightning
- WMS built engine
2002 F250 Lariat SC 4x2
- 4" turbo back, AFE Stage 1, JW valve body, AC codes, Live Tuned by Jody
2000 7.3L PSD Excursion
- John Wood built 4R100, AFE Stage 2, MBRP 4" SS turbo back, Beans 1.0 housing & WW, DP-Tuner F5 chip, V & B code spring upgrade, Bilsteins, Hellwig rear sway, ITP O/boost Annihilator and pre-pump mod.
There is nothing a bigger hammer wont fix [img]/ubbthreads/images/graemlins/smile.gif[/img]
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
I wish my lawn was Emo, cause then it would cut itself
Some people are blinded--because they have all the answers
Racerxpower.com for your upgraded E4OD/4R100 needs
