Old 04-28-2003, 05:15 PM   #1 (permalink)
Class 2 on PA Turnpike?
Recently took the Ex on a lightly loaded trip on the PA Turnpike. This road has the automatic ticket dispensers at each entrance toll booth. At each booth the Ex registered as a Class 2 vehicle (class one being the lowest). Anyone else run into this? My '00 F250SD CC w/ PSD never did this. I gotta weigh this thing sometime.
....Joe
'03 Excursion Limited: Mineral Grey/Med. Parchment , 7.3 PSD, DVD, 3.73 LSD. Sylvania Silverstars- 9007 Headlights 9005 Fog Lights, K&N, Ram Air. Yakima rack with Yakima box.
Contemporary Classics 427 Cobra replica :
428CJ, Toploader, Jag Rear 11.80's @ 122
Suzuki RGV 250 2 stroke road bike
Yamaha YZ 250F 4 stroke dirt bike
ain't that backwards!
427Cobra is offline
Old 04-28-2003, 06:34 PM   #2 (permalink)
Re: Class 2 on PA Turnpike?
Huh??? [img]/ubbthreads/images/graemlins/confused.gif[/img] I travel on the PA turnpike all my life - just take the ticket. I GUESS the toll collecter could hike your toll at the other end for your GVW, but it has never happened to me, either in my F350, or my Ram 2500.
Now, once, coming across the Walt Whitman from Jersey back into Philly, the Del Riv Port Auth toll collecter jacked my toll, but it only ever happened once.
Please elaborate on you statement.
2004.5 Ram 3500 Quad Laramie Dually 4x4 CTD 48RE 4:10 L/S Bright White
Former:'01 F350 PSD Supercab Shortbed SRW 4x4, ZF6, APX1, Lariat, Black Clearcoat w/Medium Parchment, BFG ATs (285s), Autometer Sport-Comp Pyro/Boost, Bully Dog 4" turbo-back, SP Diesel intake
wexman is offline
Old 04-28-2003, 07:50 PM   #3 (permalink)
Last November taking the PA Turnpike and got hit with the class 2. Prior trips I had not. Tollboth attendant told me the vehicle gets weighed automatically when you get your ticket and if it exceeds 7000 lbs i think then you move to the next class. I had just filled the tank and had alot of stuff in the ex. On the way back I did I was alot lighter and didn't fill the tank. It's only afew bucks difference.
Zachary is offline
Old 04-28-2003, 08:15 PM   #4 (permalink)
Well, this is interesting. Maybe only some exits have the scales?
Last weekend, I entered the turnpike at Mid County (Norristown), and took the NE Extension to Allentown. Toll was the same as a car, $1.45, I think. Two other PSDs with me - no problems either.
wexman is offline
Old 04-28-2003, 08:38 PM   #5 (permalink)
rock_doctor's Avatar
Yea ain't that a trip... I use the turnpike quite often and my suburban goes as a class 1 (barely) but the Excur is always a class 2. I guess it sits on the break point as I have had it fully loaded and is still a class 2. So it was not a mistake.
mark
2005 Excursion w/ 6.0L PSD
rock_doctor is offline
Old 04-29-2003, 12:01 AM   #6 (permalink)
Whenever I am back home in Pa I stay away from the automatic ticket dispenser. It always gives me a class 2 ticket but the toll booth attendents just charge class 1 for the X. This is on the toll road from New Stanton to Delmont around Greensburg.
<font color="blue"> 2000 X </font> Walker BTM, Superchips Micro Tuner, AMSOIL Dual-Remote Filter & Air Cleaner, Rancho 9000 Shocks, TTT Mirrors, Z-series gauges,203 degree Thermostat www.oilsandlube.com
Zyglo_Kid is offline
Old 04-29-2003, 12:13 AM   #7 (permalink)
I used to have respect for PA.,some pair they got.Everyone's in the working mans pocket today. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
My Photos
<font color="red">2002 EXCURSION, PSD, XLT Premium, 4X4, Medium Wedgewood Blue,8' Meyers E-Z Mount Snow Plow,14.1" rear LCD video monitor and DVD, FS2500 bypass oil filter, Mobile 1 synthetic ATF, Rotella T 5w-40 synthetic oil, Baldwin transmission filter, K&N filter charger with Zoodad mod., Banks Trans Command, Bilstein shocks, Rancho steering stabilizer, Hellwig rear anti-sway, XM Commander satellite radio, C-Bet'r convex mirrors, factory remote start, daytime running lights, Silverstar headlamps, "Xtra" reverse lights, Hidden Hitch front hitch receiver.Cabela's Winter Grill Cover by Fria</font>
1996 Ford Crown Victora P-71, white, blue cloth buckets, super clean and super fast.
2006 Subaru Forester 2.5X Premium(I highly recommend it in snowcountry)
2005 Gulf Stream Canyon Trail 29TEBH,with Reese D/C HP
JOE_M is offline
Old 04-29-2003, 11:57 AM   #8 (permalink)
....Joe
Probably the weight that's putting you over. Remember, an unloaded 2 wheel drive Ex is going to easilly tip the scales at well over 7500#, a 4 wheel drive is several hundred pounds heavier, quite a bit heavier than your F250 CC weighed.
Mine, unloaded with a full tank weighed 7600# without me in it!
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 04-29-2003, 12:57 PM   #9 (permalink)
This happened to me on the PA, OH, and IN turnpikes. It is right on the edge, even when not loaded with stuff. Try not to hit the scale treadle hard on the entry tollbooth. If you have a chance to use a manual lane, do so, because none of the attendants think an Excursion is class 2 (I've had some tell me the cost at the exit booths and then do a double take when the computer reads the ticket and tells them the higher class 2 amount!)
It's the opposite when you're driving a SRW pickup: when you pull up to the booth with a diesel engine, they immediately assume you are a higher rate and do what my wife and I call "the dually glance" towards the back of the truck before deciding what to charge you.
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
frobozz is offline
Old 04-29-2003, 03:05 PM   #10 (permalink)
I have been on the PA pike numerous times and Gov. Ed Rendell always charge me class 2. It has happened at mid county, Allentown, Rte 1 etc. I guess the persons with the GMC imitation Excursion is really not considered a truck or they would be paying class 2 also. Let us face it if you want a car buy one. If you want an Truck that seats 8 buy an Excursion .
Ezra Excursion is offline
Old 04-29-2003, 03:16 PM   #11 (permalink)
Well, it's purely based on weight, not how worthy your vehicle is. Though in this case, of course ('burb vs Excursion), it ends up being the same thing, hee hee...
I would add "If you want a truck that seats *9*, buy an Excursion XLT!"
We always get the front bench ('89 Suburban, '97 CC, '00 X, '03 CC), that seat comes in handy sometimes.
Duncan
frobozz is offline
Old 04-30-2003, 09:30 AM   #12 (permalink)
it is strickly in the approach, slow way down before hitting the box with no abrupt braking and it will spit out a class 1.
Dave
VMaxDave is offline
» Sponsor Links
»Garage Storage and Cabinets
