Old 04-23-2001, 08:18 PM   #1 (permalink)
Clunk over bumps
It's always sort of been there, a clunk under the floor board area when you hit a big bump a certain way. Never hear it on the highway, only around town. I know, bad Michigan roads, but it should not be there. Has anyone had the sway bar end links replaced or the cab mount bolt under the drivers feet? Everything is tight, but it still occurs. Any new ideas? I like this truck alot even without the diesel(coulda had a V8) but this clunk has got to go.
xr7gt is offline
Old 04-23-2001, 10:19 PM   #2 (permalink)
Re: Clunk over bumps
My wife drives an X like yours and I have heard the same noise many times. Seems to happen when the front right tire goes over a bump or hole but not every time. At first I thought it was a broken motor mount or something heavy bouncing around. Haven't done anything about it yet and it's going on a year
01 250 crew 4x4 psd auto
00 X v-10 auto
Billibo is offline
Old 04-23-2001, 11:03 PM   #3 (permalink)
There's a TSB out for the clunking that comes from the left rear. I had that one done but the clunking is back. I also now have clunking up front, and it feels like it's coming underneath the driver's seat area, possibly a swaybar link or something. I agree that is is very annoying.
This is one in a list of several things that's getting fixed on my Excursion when it goes in for service this Friday. Will post my results, but it won't be until next week.
-Eric
'67 Galaxie Pics | '00 Excursion Pics
erlong is offline
Old 04-24-2001, 01:09 AM   #4 (permalink)
My X did the same thing when new. I don't think it is the cab mounts as it is quite different from the CC which does have a cab mount bushing problem which WILL be fixed this Friday. My clunk went away after I changed shocks, steering stabilizer, and tires. I think it had to do with the X bottoming out frequently because of the inadequate travel distance between the bump stop and the top of the spring pack which is a measely 1/2". I am not sure which item(s) did the trick as they all happened within a few thousand miles. Now that I have the 550 springs, I have plenty of spring travel, almost 3". I note that xr7gt has changed shocks/steering stabilizer. Perhaps he should check his shocks again as there have been some reports of premature failure of the IAS shocks.
2000 Excursion LTD 4x4, Oxford White, PSD 3.73,K&N, PPIII, Dynomax, Ramsey Winch Mount/Grill/Brush Guard, Edelbrocks, Rancho SS, Hellwig Stabilizer, PIAA 90 PRO XT Lights, 295 BFG's, X springs, 2000 F350 CC PSD 4x4 Woodland Green, 3.73 K&N, PPIII, 295 BFG's, Edelbrocks
POLR BR is offline
Old 04-24-2001, 01:45 AM   #5 (permalink)
I'm running RS9000's up front and a pro comp stabilizer shock. Still running the stock leaf springs and tires..definitely clunky. We'll see what the dealer comes up with.
-Eric
erlong is offline
Old 04-24-2001, 09:53 AM   #6 (permalink)
Thanks for the replies. It does seem occur when the right front tire hits a bump, then travels toward the drivers side. I think some sort of lateral movement of the sway bar causes the drivers side upper link to move. I removed the dogbone(link) on the drivers side and noticed there is excessive play where the bolt comes out of the wheel side of the frame. You can see where some of the frame coating is worn larger than the outline of the nut.
The problem is the larger size of the sway bar with weak end links. Just a poor design. I would consider the Hellwig, but it uses the stock end links. Another solution might be to replace the axle mount bushings with poly-urethane, but I have not found a supplier. I think this may limit some of the excess movement of the bar. Plr Br, do you think the Hellwig helped?
I have to go to dealer for dead running board lights on drivers side(filled up with water after this winter), so I'll let them take a look at the front end.
xr7gt is offline
Old 04-24-2001, 11:54 PM   #7 (permalink)
FYI,
Energy Suspension has a full listing of polyurethane bushings for the Excursion. The sway bar bushings are part 4-5180 (36mm).
xr7gt is offline
Old 04-25-2001, 10:14 AM   #8 (permalink)
If it's a real hard clunk, I can't help you.
But, if it's a rattle/noisy/sorta clanky but w/o a metal on metal sound, it might be your exhaust system.
I always thought it was just the suspension making a racket over bumps. After I added my flexpipe the truck really quieted down over bumps. Good Luck!
2001 Black Excursion, 4x4, XLT, PSD, LS, (EBM2), Super-Duty grill, 4" MBRP exhaust, Bilsteins, X-springs, OilGuard bypass filter, 295's, Badges, Suvlights harness, APC headlights, Weatherboots, Centramatics, Clear corners, AIC w/ITP mount, ISSPRO EVs, BTS trans, Open element intake, ATS compressor housing, Thule rack, BD Torqloc, F350 rear blocks, Randy Ellis lightbar with a couple of Lightforce 170s, Front receiver hitch, DP Tuner chip
1975 Ford Bronco, neglected since I bought the Excursion
AJ'sDad is offline
Old 04-25-2001, 11:10 AM   #9 (permalink)
your fron sway bar link attaching bolts are necked down to reduce weight. consiquenltly, portions of the bolt are significantly smaller than the hole they go through. When you experience a hard jounce, the link/bolt moves and you hear the clunk.
Replace the factory bolts with some grade 8 1/2" bolts and locknuts (minor line reaming of the holes may be required) and your problems will go away. [img]images/icons/wink.gif[/img]
RECYCLED RACING TEAM - VHS 82BP
Conserve resources, recycle old racecars.
http://home.att.net/~rr-team/
Y2K X PCMs-AXDO/AXD1/MQJ0/????next
Recycled Racing is offline
Old 04-25-2001, 03:04 PM   #10 (permalink)
More good replies, I don't think it is the exhaust but I'll look. The point about the fasteners is great. That way I could avoid the Ford dealer. Thank's
xr7gt is offline
» Sponsor Links
»Garage Storage and Cabinets
